Hi all,
Currently new to Arduino, I'm currently running into problems with my current project and would like some help / advice.
Project application:
I have a sensor that will be checking if an item is in its field, if there is not for 3 seconds (time value subject to change) then it will alarm (Sending signal to a speaker + Light flash and display to lcd "Check Feed Tube". This will continue to alarm until there is an item in its field. Each alarm will reset its duration once the condition is cleared.
I have currently got the speaker + light flash along with the lcd to display text, my issue is with the time and resetting the clock. I have got it to signal every 3 seconds with millis() by making it check current millis() and then subtract it and check if it is >= 3000. However it does not seem to reset millis() back to 0 and reset the loop. it will continue to add to millis().
I currently am using a ultrasonic distance sensor as the Sensor to mimic a sensor triggering back.
Please see code below.
// C++ code
#include <Adafruit_LiquidCrystal.h>
float dist = 0;
unsigned long previousMillis=0;
int interval=3000;
Adafruit_LiquidCrystal lcd_1(0);
long readUltrasonicDistance(int triggerPin, int echoPin)
pinMode(triggerPin, OUTPUT); // Clear the trigger
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
// Sets the trigger pin to HIGH state for 10 microseconds
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
// Reads the echo pin, and returns the sound wave travel time in microseconds
return pulseIn(echoPin, HIGH);
pinMode(13, OUTPUT);
pinMode(12, OUTPUT);
lcd_1.begin(16, 2);
lcd_1.setBacklight(1);
lcd_1.setCursor(0, 0);
lcd_1.print("Operational");
lcd_1.setCursor(0, 1);
lcd_1.print (millis());
dist = 0.01723 * readUltrasonicDistance(1, 1);
delay(10);
if (dist < 100 && ((unsigned long)(currentMillis - previousMillis) >= interval))
digitalWrite(12, HIGH);
tone(13, 500, 250);
delay(200);
tone(13, 600, 250);
delay(200);
tone(13, 700, 250);
digitalWrite(12, LOW);
delay(200);
tone(13, 800, 250);
delay(200);
lcd_1.clear();
lcd_1.print("Check Feed Tube");
lcd_1.print(currentMillis);
delay (1000);
digitalWrite(13, LOW);
