Serial communication between 2 X ESP8266s
I want to send a character string from one ESP8266 to another ESP8266 via the Tx and Rx pins.
The two processors are mounted on a breadboard, the Tx pin of one is connected to the Rx pin of the other. The two gnd pins are connected and the ESPs are powered separately via USB connectors.
The problem is that the received data is a series of digits, not the character string that was sent.
Here is the transmitter code
#define led_pin 2
  pinMode(led_pin, OUTPUT);
  digitalWrite(led_pin, HIGH);   // off
  while (!Serial);            // wait for Serial Monitor to open
  Serial.println('aa;bb;cc\n');    // send data to Tx pin
  digitalWrite(led_pin, LOW);      // flash the on board LED
  delay(10000);
and this the receiver code
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean newData = false;
    Serial.println("<Arduino is ready>");
    recvWithEndMarker();
    showNewData();
void recvWithEndMarker() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (rc != endMarker) {
            receivedChars[ndx] = rc;
            ndx++;
            if (ndx >= numChars) {
                ndx = numChars - 1;
        else {
            receivedChars[ndx] = '\0'; // terminate the string
            ndx = 0;
            newData = true;
void showNewData() {
    if (newData == true) {
        Serial.print("This just in ... ");
        Serial.println(receivedChars);
        newData = false;
The receive ESP is connected to a USB port on a PC, this is what is displayed on the monitor:
This just in ... 996369162
Any help would be appreciated
Try with
Serial.println("aa;bb;cc");
Double quotes, and println already includes \n.
doesn't the IDE use the serial interface pins, TX and RX?
so you connect the 2 board with those pins and then use Serial.print() to display what you receive using the Serial monitor.
shouldn't you connect the boards together using a 2nd serial interface and configure that interface as well?
also, if you just looking for a single end-marker such as '\n', why not use Serial.readBytesUntil()?
if your considering doing something more elaborate, such as start bytes plus checksum and plan on sending binary data (not just ascii), you need a routine that checks for each starting byte, restarting if it finds bytes out of sequence and then capturing some specified # of bytes and finally checking the checksum.
println() includes '\n' (Newline character) which is transmitted as a frame; but, double quotes includes '\0` (null character) which is not transmitted; but, it is used by Sender to detect the end-of-string.
Re-write the above as:
Simplified version of your non-blocking Receiver Sketch:
int index = 0;
   byte n = Serial.available();
   if(n != 0 )   //there is charcater in buffer
     char rc = Serial.read():
     if(rc != '\n`)     //Newline charcater has not yet arrived
         receivedChars[index] = rc;    //save character
         index++;   //point next location of arry
         if (index >= numChars)
            index = numChars - 1;     //keep last location of user array to hold null
     else   //Newline charcater has arrived
          receivedChars[index] = '\0';  //insert null character
          Serial.println(receivedChars);  //show charcaters on serial Monitor
          index = 0;   //reset array index for the next cycle
OP has made a non-blocking sketch.
why does that matter unless you start queueing up bytes to send but then wait a while before sending the rest or if your transmitting at a very low rate and need the time between chars to do something else
OP's receiver spends time in while() loop to receive characters which is similar to mine receiver spending time in main loop() in the non-blocking sketch of post #6.
Thank you so much for the many replies (and quickly too!)
Changing the transmitted string from single quite to to double quote does the job.
I was hoping to get away with using the monitor on Rx chip for the purpose of testing the data transfer. I'll now forward the received data to my NAS device via wifi and ftp.
The Tx chip will be acquiring data via NOW from a remote ESP chip.
Thanks again.
Solution is to be marked on post #2 @kmin who suggested for the first time to put double quotes.
OK, didn't realise. Thanks
