Hi!
So I bought an ESP8266 ESP-12E UART WIFI SHIELD (which is the moer info $ version) I successfully installed it in the arduino which is the rx to rx and tx to tx. Sadly I can't figure out how to do serial communication using the serial software :((
Tried using the SoftwareSerial s(0,1) but nothing happened, I cant figure out which pin should I put it :((
Google is usually helpful... How to connect Wi-Fi shield ESP-12E-ESP8266-UART-WIFI-Wireless-Shield with Arduino - Arduino Stack Exchange
Hello,
I tried dr. google:
Arduino UNO + ESP8266 ESP-12E UART WIFI Shield | by Attila Varga | Medium
It seems you have to program the ESP first so you can send serial data to the thing.
SoftwareSerial is not necessary as pin 0 and 1 are hardware serial output ports that also send serial data to your USB to serial convertor 16U2 installed on your UNO board.
Best Regards,
Johi
Take a look at
drmpf:
Take a look at
https://www.instructables.com/ESP8266-ESP-12E-UART-Wireless-WIFI-Shield-TTL-Conv/
I think this is the only solution since the transistors is wrong :< unfortunately I have no knowledge when it comes to soldering and I'm new to Arduino, Maybe I'll bought a shield again that is not clone, Thank you!!
blh64:
Thank you! The wifi shield is working properly, I uploaded the helloserver and it is working properly but still can't send data from arduino uno to the esp8266 :<
JOHI:
Hello,
I tried dr. google:
Best Regards,
Johi
Followed all the steps but still didn't work for me :< Thanks for the help though!
So how do you have it connected now ? What is the exact board you are using ? (please provide link) There are many versions of the ESP8266 12-E as they are used in development boards like the nodeMCU.
If you want to send data from the ESP to the UNO, you connect TX (esp) -> RX (Uno) & RX (esp) <- Voltage-divider <- TX (uno), but here is where it sometimes doesn't quite work the way you expect. Some of the Dev boards don't work receiving through the voltage divider, but only some ! Stay safe first use the voltage divider !!
Receiving on the Uno is a different matter, you should try first with a very basic sketch. Upload
Serial.print("A");
Serial.print("B");
to the ESP, and upload
pinMode(13, OUTPUT);
if (Serial.available()) {
char c = Serial.read();
if (c == 'A') digitalWrite(13, HIGH);
if (c == 'B') digitalWrite(13, LOW);
to the Uno, and your ESP should be remotely 'blink' the Uno's built in led.
Deva_Rishi:
Receiving on the Uno is a different matter, you should try first with a very basic sketch. Uploadvoid setup() {
Serial.print("A");
Serial.print("B");
to the ESP, and uploadvoid setup() {
OMG THANK YOU SO MUCH IT IS WORKING YOU ARE A LIFE SAVER. I REALLY MEAN IT THANK YOU SO MUCH IM CRYING RN CAUSE I CAN'T SLEEP FOR 3 DAYS STRAIGHT RESEARCHING FOR THIS.
I bought the ESP8266 ESP12-E UART WIFI SHIELD which is the moar info $ tech version (clone) https://shopee.ph/product/299014880/5048600547?smtt=0.396683011-1618152297.9?smtt=0.396683011-1618152297.9
I remove the pin (0,1) from the shield and out wires to the debug port of the esp which works because it can run the hello server
Here is the vid I followed https://youtu.be/w-6_3dBLUaY
I followed what you said and it is now working the lights are blinking and I'm crying thank you so much
P.S. I don't know how to upload the photo since I'm new here in this forum and whenever I click the attachments it gives me a link to put
Deva_Rishi:
Serial.print("A");
Serial.print("B");
What if it is from arduino uno to the wifi shield?
The same thing should apply with reverse uploading the sketches, though i am not sure which pin the internal led on the esp is connected to (if there is one)
hmm so this is the one. When connecting the RX(ESP) <- Uno (TX) do not omit the voltage divider. The ESP is not 5v tolerant ! You can connect an LED + 470R resistor to any pin and simply define that as the LED output pin.
