Serial Communication Hex commands
Hi Guys
I am working on a communication with a PC.
I need to send a Hex command called "x14CAP".
Using Serial.println() doesn't work.
This is my code:
`> //@AB Electronic 2022 con comando Start
String valor;
int Rele = 2; //Perto Salida Digital para el Rele
int Sensor = 3; // Puerto Entrada Digital para el sensor de presencia de placa
void setup(){
Serial.begin(19200);
pinMode(Rele,OUTPUT);
pinMode(Sensor,INPUT);
void loop(){
if (digitalRead(Sensor) == LOW){
Serial.print("Envio comando Start");
Serial.println("/x14C"); //Envío comando Stop
Serial.println("/x14CAP"); //Envío comando Start
do {
} while (Serial.available() == 0);
if (Serial.available() > 0){
valor = Serial.readStringUntil('\n'); //Leemos hasta encontrar RC
valor = valor.substring(valor.length()-4, valor.length()-1); //Cogemos los 3 ultimos caracteres
Serial.print("VALOR: ");
Serial.print(valor );
//Valor recibido VeriSpector OK
if (valor == "B01") {
Serial.println("Resultado OK ");
digitalWrite(Rele, HIGH); //Rele activado
delay(5000); //1 seg Rele activado
digitalWrite(Rele, LOW); //Rele  cortado
//Valor recibido VeriSpector NOK
 if (valor == "B02") {
Serial.println("Resultado NOK ");
valor == "";
Thanks for any help
Welcome to the forum
Why have you got forward slashes in the string that you are printing ?
You seem to be printing both commands and text to the same Serial interface. That does not sound right
Which Arduino board are you using ?
Which pins on the board is the device connected to ?
Hi UKHeliBob
I found a mistake. This is the description of the command I got:
Arduino Uno
It is connected by a RS-232/TTL board
Thanks
P is not part of hexadecimal, can you clarify exactly what bytes you need to send?
I cannot read what you got
If you are expecting to see messages printed to the Serial monitor and also to send commands to the device then you will need 2 separate serial interfaces, hence my question as to which board you are using and which pins the interface to the device is connected
Please help us to help you by supplying full information
Hi Jackson
I was told to send command \x14CAP (ask for image capture) and \x14C (stop inspection).
I get command B01 and B02 in return without any problem.
Thanks
Ok so the byte 0x14 followed by ascii chars CAP ( for capture i assume)
You could do this to spell things out
deviceSerialPort.write(0x14);
deviceSerialPort.print("CAP");
deviceSerialPort Would be the serial interface to your device.
Jackson, then something like that:
while (digitalRead(Sensor) == LOW){
  Serial.write(0x14); //Envío comando Stop
  Serial.println("C");
  Serial.write(0x14); //Envío comando Start
  Serial.println("CAP");
Not sure about the ln At the end of print, the protocol does not seem to say you need to send CR a d LF, so just print
There there is the question about Serial…. Describe your circuit… because Serial is often connected to the Serial monitor….
Yes, I do need to add CR.
There is SW for image capturing installed on a PC. PC is connected to RS-232/TTL board with a cable. We use digital pin 0 and 1 for RX/TX. That works fine. At least the reception of commands from PC to Arduino.
We also control a Rele, pin 2 to say to an external device that everything was ok.
With pin 3 monitor a PLC sensor output to trigger the communication.
I hope that you have better luck than I have in getting the details or even a clue as to which Arduino is being used
Not mentioned in your image
It is not the best document.
Im going to upload the program and test the whole system.
I will let you know.
hi Jackson
My code make nothing on the PC. There is not response
Where is Serial connected to ?
Do you have a USB cable between the PC and Arduino?
How should we ask more clearly
DESCRIBE YOUR CURCUIT… please (if you want any more answer)
