Serial Communication Problem
Good day! i am having trouble with Serial Communication. I wanted the serial monitor to print the value i sent but it also prints another value other than the one i sent. For example i send 1 it displays 1 and -38. Any help will be much appreciated! Thank You.
Here is my code:
        Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
              int val = Serial.read()-"0";
                // say what you got:
                Serial.print("I received: ");
                Serial.println(val);
Here is a screenshot of the serial monitor
What has this got to do with the website or forum?
Check the serial monitor line ending.
It should be 'None'.
int val = Serial.read()-'0';
