Hy!
I want to communicate an multifunction weight indicator over Serial port using an ESP32 (Nodemcu 32-s) board.
With offical FTDI USB-RS232 controller (Chipi-X) works fine, in the arduino serial monitor i see the following:
When i try with ESP32 in the serial monitor i see nothing, or i change the connection of RX/TX pin the result is the following:
The code:
Serial1.begin(9600,SERIAL_8N1, 16, 17);
while (Serial1.available()){
Serial.write(Serial1.read());
The serial settings is correct, with ftdi device work fine.
The weight indicator is this: Dini Argeo DFWL-1
On ESP32 side i use an 3.3-5V level shifter, and the GND is connected.
What might be the problem?
Thanks!
Benji
