Nevermind i realised i had char instead of unsigned char
millis returns an unsigned long..
don't try to read all the bytes at once, keep track of how many and trigger when you have received what you expect..
try this untested sorry..
unsigned char Buffer[9];
unsigned long CurrentTime = millis();
unsigned long LastTime = 0;
const int DelayTime = 1000;
byte recvCount = 0;
Serial1.begin(115200);
Clock();
RecvData();
void Clock() {
if (CurrentTime - DelayTime > LastTime) {
LastTime = CurrentTime;
Serial.print("Clock Data: ");
SendData();
void RecvData() {
if (Serial1.available() )
unsigned char achar = Serial1.read();
if (recvCount == 0 && achar != 0x5A) return;
if (recvCount == 1 && achar != 0xA5) {
recvCount = 0;
return;
if (recvCount == 2 && achar != 0x06) {
recvCount = 0;
return;
if (recvCount == 3 && achar != 0x83) {
recvCount = 0;
return;
Buffer[recvCount] = achar;
recvCount++;
if (recvCount == 9) {
//got all bytes..
Serial.print("Button Press Data: ");
SendData();
recvCount = 0;
void SendData() {
Serial.print("Current Time: ");
Serial.print(CurrentTime);
Serial.print(" Buffer: ");
Serial.print(Buffer[0], HEX);
Serial.print(", ");
Serial.print(Buffer[1], HEX);
Serial.print(", ");
Serial.print(Buffer[2], HEX);
Serial.print(", ");
Serial.print(Buffer[3], HEX);
Serial.print(", ");
Serial.print(Buffer[4], HEX);
Serial.print(", ");
Serial.print(Buffer[5], HEX);
Serial.print(", ");
Serial.print(Buffer[6], HEX);
Serial.print(", ");
Serial.print(Buffer[7], HEX);
Serial.print(", ");
Serial.print(Buffer[8], HEX);
reads one byte at a time..
checks for proper header..
good luck.. ~q
That works perfectly , thankyou very much now to go through and learn what you did.
Much appreciated!
