So I'm trying to write a Java programm that communicates with a arduino uno and turn on or off an led.
Arduino Code:
const short bt0 = 4; //Raum Knopf
const short bt1 = 5; //Haus Knopf
const short bt2 = 6; //fn0
const short bt3 = 7; //fn1
const short led = 3; //Raum Licht
//Status der Bauteile (Knopf gedrückt ode nicht; LED an oder nicht?)
short bt0std = LOW;
short bt1std = LOW;
short bt2std = LOW;
short bt3std = LOW;
short ledstd = LOW;
String incomingString;
short tmp; //tmp var for comparisons
boolean changesMade = false;
//int msgId = 0;
boolean receiveData() {
if (Serial.available() > 0) {
incomingString = Serial.readString();
incomingString = incomingString.substring(0, incomingString.length() - 1);
Serial.println(incomingString);
return true;
return false;
//Funktion zum umschalten der LED
void toggleLED() {
if (ledstd == LOW) {
digitalWrite(led, HIGH);
ledstd = HIGH;
sendData("lhon");
digitalWrite(led, LOW);
ledstd = LOW;
sendData("lhof");
//Funktion zum Senden von Daten (z.Z über den Seriellen Port)
void sendData(String data) {
String outgoingString = "src-id:1dst-id:0msg-id:1";
//outgoingString += msgId++;
outgoingString += "msg:";
outgoingString += data;
Serial.println(outgoingString);
Serial.begin(9600); //Serielle verbindung starten
//Funktion der pins festlegen
pinMode(bt0, INPUT);
pinMode(bt1, INPUT);
pinMode(bt2, INPUT);
pinMode(bt3, INPUT);
pinMode(led, OUTPUT);
if (receiveData()) {
if (incomingString == "on") {
toggleLED();
sendData("lhon");
} else if (incomingString == "off") {
if (ledstd == HIGH) {
toggleLED();
sendData("lhof");
tmp = digitalRead(bt0);
if (tmp != bt0std) {
if (tmp == HIGH) {
bt0std = HIGH;
toggleLED();
changesMade = true;
bt0std = LOW;
changesMade = true;
tmp = digitalRead(bt1);
if (tmp != bt1std) {
if (tmp == HIGH) {
sendData("home");
bt1std = HIGH;
changesMade = true;
bt1std = LOW;
changesMade = true;
tmp = digitalRead(bt2);
if (tmp != bt2std) {
if (tmp == HIGH) {
sendData("fn0");
bt2std = HIGH;
changesMade = true;
bt2std = LOW;
changesMade = true;
tmp = digitalRead(bt3);
if (tmp != bt3std) {
if (tmp == HIGH) {
sendData("fn1");
bt3std = HIGH;
changesMade = true;
bt3std = LOW;
changesMade = true;
if (changesMade) delay(100);
Java code:
import gnu.io.CommPort;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import java.io.FileDescriptor;
import java.io.IOException;
import java.io.InputStream;
import java.io.OutputStream;
public class TwoWaySerialComm
public TwoWaySerialComm()
super();
void connect ( String portName ) throws Exception
CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
if ( portIdentifier.isCurrentlyOwned() )
System.out.println("Error: Port is currently in use");
CommPort commPort = portIdentifier.open(this.getClass().getName(),2000);
if ( commPort instanceof SerialPort )
SerialPort serialPort = (SerialPort) commPort;
serialPort.setSerialPortParams(9600,SerialPort.DATABITS_8,SerialPort.STOPBITS_1,SerialPort.PARITY_NONE);
InputStream in = serialPort.getInputStream();
OutputStream out = serialPort.getOutputStream();
//byte[] b = String.format("on%n").getBytes();
//out.write(b);
(new Thread(new SerialReader(in))).start();
(new Thread(new SerialWriter(out))).start();
System.out.println("Error: Only serial ports are handled by this example.");
public static class SerialReader implements Runnable
InputStream in;
public SerialReader ( InputStream in )
this.in = in;
public void run ()
byte[] buffer = new byte[1024];
int len = -1;
try
while ( ( len = this.in.read(buffer)) > -1 )
System.out.print(new String(buffer,0,len));
catch ( IOException e )
e.printStackTrace();
public static class SerialWriter implements Runnable
OutputStream out;
public SerialWriter ( OutputStream out )
this.out = out;
public void run ()
try
int c = 0;
while ( ( c = System.in.read()) > -1 )
this.out.write(c);
public static void main ( String[] args )
try
(new TwoWaySerialComm()).connect("COM3");
catch ( Exception e )
// TODO Auto-generated catch block
It works when I send the data with the arduino serial monitor, but not when I send the commands via my Java programm. The command I am trying so send is "on".
