And you are testing things that, at the point of the test, are known.
You also read the pin and... do nothing.
Here I believe is your loop with all that removed:
int value = digitalRead(2);
delay(10);
Serial.println(KeyDownCounter);
// digitalRead(KeyDownPin); // does no one any good
if (digitalRead(KeyDownPin) == HIGH)
KeyDownCounter++;
else // it is LOW!
if (KeyDownCounter > 2)
Serial.println("FINAL Stop");
KeyDownCounter = 0;
As @UKHeliBob says, state change detection will serve you well. A good habit in any case is to read switches once, then use that reading for the rest of the loop.
There's a crap-ton of state change detection tutorials. Google is your friend. Read this post and the thread it finds itself on:
