Hi all,
My Windows computer is sending out a string of two chars. The first is the command number, and the second is a char marker. The Arduino sketch reads in the string, uses a switch statement to determine which command number it is and then compares the second char in the string to the defined marker (an exclamation mark). If true, it acknowledges the marker by returning a plus sign char to the sending computer.
A straightforward comparison of the second char in the read-in string to the marker did not work. I used a Serial.println statement to display the singled out second char, but it displays as an empty string.
I got the code to work by using the indexOf function to check for the marker, but I would like to know if I did something wrong when checking for it directly. Thank you for your help, and time. Code follows. Saga
//Set up serial monitor
//Wait till serial connection is established.
while (!Serial) {}
//Currently tx process only sends 1!.
if (Serial.available()) {
//I've got something, read it in into a string variable
String inData = Serial.readString();
//Displays as "1!"
Serial.println(inData); //Show raw data in Serial Monitor
//Available commands:
// 1 - Check presence. Use ! char as marker.
switch (inData.substring(0, 1).toInt()) {
case 1:
//Displays as "Mark: *"
Serial.println("Mark: " + inData.substring(1, 1) + " *"); //Show only marker
// Check the mark to see if this is the correct device.
if (inData.indexOf("!") > 0) {
//if (inData.substring(1, 1) == "!") {
//The above commented IF statement does not work.
//Send confirmation char to host to let it know that this is the
//correct device.
Serial.print("+");
