Serial Monitor auf LCD Display übertragen, funktioniert nicht richtig
ich arbeite gerade mit einem LCD-Display und einem Arduino Uno.
ich habe den Code aus dem Tutorialsbereich von Arduino raus kopiert, dieser funktioniert auch einwandfrei bis auf das am Ende immer ein komisches Zeichen ist. Ich hatte es dann auch mit dem lcd.print() Befehl probiert, jedoch gibt dieser dann nur eine Zahlen Kette aus.
  LiquidCrystal Library - Serial Input
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch displays text sent over the serial port
 (e.g. from the Serial Monitor) on an attached LCD.
 The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 modified 7 Nov 2016
 by Arturo Guadalupi
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystalSerialDisplay
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // initialize the serial communications:
  // when characters arrive over the serial port...
  if (Serial.available()) {
    // wait a bit for the entire message to arrive
    delay(100);
    // clear the screen
    lcd.clear();
    // read all the available characters
    while (Serial.available() > 0) {
      // display each character to the LCD
      lcd.write(Serial.read());
Kennt sich jemand damit aus?
Im englischen Teil des Forum müssen die Beiträge und Diskussionen in englischer Sprache verfasst werden.
Deswegen wurde diese Diskussion in den deutschen Teil des Forums verschoben.
mfg ein Moderator.
Du musst prüfen, ob das Zeichen, dass Du mit Serial.read() einliest, ein druckbares Zeichen ist. Grob, ob es >= 0x20 ist.
Gruß Tommy
Ja.
Im seriellen Monitor findest Du ein Kombifeld aus dem Du auswählen kannst zwischen:
"NEUE ZEILE"
"ZEILENUMBRUCH"
"SOWOHL NL ALS AUCH CR"
"KEIN ZEILENENDE"
Genau letzteres stellst Du ein.
