Serial Monitor false prints
sketch_SMButton.ino (479 Bytes)
Goodday everyone,
I have attached the .ino file to this.
I am trying a simple sketch to turn on an LED when pressed (following a Youtube video tutorial.) I used an "if" condition statement to read the button and turn on an LED and also print some text on the Serial monitor.
When i upload the code, the Serial monitor prints the text even without pressing the button vut the LED works as supposedly.
I have both the SM and LED code in the "if" statement but only the LED follows the instruction.
int buttonpin = 6;  //push button
int ledyellow = 7;  //yellow LED
float delset = 0;   //delay set time
int pinread;
  pinMode(buttonpin, INPUT_PULLUP);
  pinMode(ledyellow, OUTPUT);
  pinread = digitalRead(buttonpin);
  if (pinread == LOW) {
    //delset = delset + 5;
    Serial.print("ms > ");
    Serial.println(delset);
    digitalWrite(ledyellow, HIGH);
    else {
      digitalWrite(ledyellow, LOW);
I doubt anybody here will click that link. Please post your entire code using code tags.
Can you please descibe how i do that? I post from a mobile device web browser.
**edit
Nevermind.
Never is a long time.
Did you try initializing pinread state?
  pinread = HIGH;
then in void loop() resetting the state?
    else {
    pinread = HIGH;
Full Sketch (as I tested it, you'll have to change the LED pin back):
int ledyellow = LED_BUILTIN;  //yellow LED
int pinread;
  pinread = HIGH;
    else {
    pinread = HIGH;
Thanks @hallowed31
Would try this and revert.
