Serial Monitor in Console of Arduino App Lab 0.2.0 showing nothing
Tried following simple code:
//**********Routerbridge for Arduino Q ****
#include <Arduino_RouterBridge.h>
// Initialize the Monitor
Monitor.begin();
Monitor.println("===============================================");
Monitor.println("Initial Message");
Monitor.println();
Monitor.println("Recurring message");
Monitor.println();
Compiled without error
Sketch profile configured: FQBN="arduino:zephyr:unoq", Port=""
The library ArxContainer has been automatically added from sketch project.
The library ArxTypeTraits has been automatically added from sketch project.
The library DebugLog has been automatically added from sketch project.
The library MsgPack has been automatically added from sketch project.
Sketch uses 17568 bytes (0%) of program storage space. Maximum is 1966080 bytes.
Global variables use 4676 bytes (0%) of dynamic memory, leaving 518948 bytes for local variables. Maximum is 523624 bytes.
Open On-Chip Debugger 0.12.0+dev-ge6a2c12f4 (2025-05-22-15:51)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 2
clock_config
/tmp/remoteocd/sketch.elf-zsk.bin
Info : Linux GPIOD JTAG/SWD bitbang driver (libgpiod v2)
Info : Note: The adapter "linuxgpiod" doesn't support configurable speed
Info : SWD DPIDR 0x0be12477
Info : [stm32u5.ap0] Examination succeed
Info : [stm32u5.cpu] Cortex-M33 r0p4 processor detected
Info : [stm32u5.cpu] target has 8 breakpoints, 4 watchpoints
Info : [stm32u5.cpu] Examination succeed
Info : [stm32u5.ap0] gdb port disabled
Info : [stm32u5.cpu] starting gdb server on 3333
Info : Listening on port 3333 for gdb connections
CPU in Non-Secure state
[stm32u5.cpu] halted due to debug-request, current mode: Thread
xPSR: 0x41000000 pc: 0x0801748c psp: 0x2002ccf8
Info : device idcode = 0x30016482 (STM32U57/U58xx - Rev W : 0x3001)
Info : TZEN = 0 : TrustZone disabled by option bytes
Info : RDP level 0 (0xAA)
Info : flash size = 2048 KiB
Info : flash mode : dual-bank
Info : Padding image section 0 at 0x080fbae8 with 8 bytes (bank write end alignment)
Warn : Adding extra erase range, 0x080fbaf0 .. 0x080fbfff
shutdown command invoked
python provisioning
python downloading
Network printserialmonitor_default  Creating
Network printserialmonitor_default  Created
Container printserialmonitor-main-1  Creating
Container printserialmonitor-main-1  Created
Container printserialmonitor-main-1  Starting
Container printserialmonitor-main-1  Started
but nothing is showed in “Console” –> “Serial Monitor”.
What I’m missing?
Thanks in advance for your guidance.
There are a couple other threads on this, but @ptillisch explained it
nicely in his response.
Thanks for swing answer @KurtE but unfortunately I was aware of the post and the documentation you are mentioning. The problem is that the suggested approach: https://docs.arduino.cc/tutorials/uno-q/user-manual/#uart is to use, exactly as I did, Monitor.println. Exact quote from official documentation:
From Serial to Monitor
Because of the UNO Q’s architecture, using
Serial
does not display data in the Arduino App Lab Serial Monitor as you might expect.
To make debugging just as easy as on other Arduino boards, we provide the
Monitor
object, which you can use to print debugging messages, sensor readings, or any other information directly to the Serial Monitor.
You can do exactly the same, but with a minor prerequisite; including the
library in your sketch
But, as I described, nothing is visualized within Console –> Serial Monitor.
Unfortunately the mentioned posts don’t address the issue I’m having currently.
Hi @apagliari. Are you using the UNO Q in "single-board computer mode", or are you instead running Arduino App Lab on your PC?
If the latter, which operating system are you running on your PC?
I ask because the developers investigated some previous reports of users not seeing the output of the sketch in Serial Monitor and did discover a bug in Arduino App Lab that affects Windows users.
HI @ptillisch thanks for stepping in :grinning_face:
I’m running Arduino App Lab on my PC where Windows is
Edition Windows 11 Pro
Version 24H2
Installed on ‎09/‎02/‎2025
OS build 26100.6899
Serial number PF41QXXK
Experience Windows Feature Experience Pack 1000.26100.253.0
Hope this will help sheding a light.
Thanks a lot for your support
Thanks for the clarification. So this is a known bug and a fix is in progress. The fix will be in the next release of Arduino App Lab. App Lab automatically updates, so you will receive the fix as a matter of course as soon as the developers make the release.
Thanks for swing answer :grinning_face:
Can’t wait to getting the new working version since this is a pretty relevant functionality when porting older arduino sketches into the new environmente and trying to let them work. Is there an idea about the release date of the new version?
Thanks @ptillisch,
Wondering if you have any additional information on this.
I tried running the simple sketch above and did not see any output, to Serial monitor
on PC. Nor on TyCommander on my PC.
More specifically I am curious if it is related to issues I have seen on Zephyr
directly with other boards like Giga/Portenta H7, where for example I use
a modified version of the Camera Capture sample app that outputs to USB.
I have a version that outputs in two formats. One that can talk to the Arduino Camera
PC Processing app (extras) and it works on Ubuntu, but does not appear to work well
on Windows. However it does talk to the Arducam Mini app on Windows.
Earlier when I tried to debug this, it was like, the zephyr USB_NEXT serial was getting
through the logical if(Serial) type test. Like waiting for DTR or ...
EDIT: verified again with simple sketch uploaded through Arduino IDE.
  pinMode(LED_BUILTIN, OUTPUT);
  for (uint8_t i = 0; i < 5; i++) {
    digitalWrite(LED_BUILTIN, HIGH);
    delay(250);
    digitalWrite(LED_BUILTIN, LOW);
    delay(250);
  Monitor.begin(115200);
  while (!Monitor && millis() < 5000) {}
int loop_count = 0;
  Monitor.println(loop_count++);
And no output in Serial monitor. Now hooking up USB To Serial adapter
Thanks again
Previously, I wasn't able to link to the fix due to the fact that the repository in which it was located had not yet been made publicly visible. The repository has now been published :tada:, so you can see the fix here:
Note that it has already been merged, but there hasn't been a new release since that time, so the fix is still not present in the release version of Arduino App Lab.
Considering this is version 0.2.0 I guess it is not too surprising that there are some bugs. Are known bugs posted some place? It could save us a lot of time to know things like this. I do not mind waiting for a bug fix on something so new, but it nicer to hear about known issues than to spend time trying to get code to work when the actual issue is beyond our control.
Hi @danpeirce. Most of the software components used by the UNO Q board are hosted in public GitHub repositories. The issue trackers in those repositories are used to track bugs and feature requests specific to the given component:
:red_exclamation_mark: These issue trackers are only to be used for tracking high quality bug reports and feature requests. They are not an appropriate place to request support or conduct general discussions.
Support requests and unstructured discussions are always welcome on Arduino Forum.
Component Purpose Tracker Link
Arduino App Lab App development :cry: None
Arduino App CLI App management :link: here
Arduino CLI Compile and upload sketch, manage sketch dependencies :link: here
arduino-router Linux communication w/ sketch :link: here
remoteocd Upload tool (hosted mode) :link: here
App examples Documentation :link: here
Preinstalled Bricks App components :link: here
arduino/ArduinoCore-zephyr "UNO Q Board" platform :link: here
Arduino_RouterBridge Arduino library for sketch communication w/ Linux :link: here
Arduino_RPClite Arduino library for sketch communication w/ Linux :link: here
Arduino Flasher CLI: Manual Linux image updates :link: here
arduino/linux-qcom Linux kernel :link: here
arduino/arduino-deb-images Linux image infrastructure :link: here
u-boot Linux bootloader :link: here
I have an update to make on my previous reply. Development of the Arduino App Lab codebase is now done in a public GitHub repository:
That repository has an issue tracker that can be used to submit formal bug reports and feature requests:
This will also make it easier for the community to track progress by the developers on resolving those issues.
