Serial monitor issue with ESP32-C6
Hello,
I am trying to use the ESP-NOW master code and not having luck with serial monitor.
I inserted a "testing" just after serial begin in Setup. I tried delays of 4 seconds, I tried while(!serial). Nothing seems to put anything on the serial monitor. My code compiles and uploads without issue. BTW, I tried the slave code with the same "test" and it does not output anything either. See code, I would appreciate any help to get this working. thanks!
#include "ESP32_NOW.h"
#include "WiFi.h"
#include <esp_mac.h>  // For the MAC2STR and MACSTR macros
/* Definitions */
#define ESPNOW_WIFI_CHANNEL 6
/* Classes */
// Creating a new class that inherits from the ESP_NOW_Peer class is required.
class ESP_NOW_Broadcast_Peer : public ESP_NOW_Peer {
public:
  // Constructor of the class using the broadcast address
  ESP_NOW_Broadcast_Peer(uint8_t channel, wifi_interface_t iface, const uint8_t *lmk) : ESP_NOW_Peer(ESP_NOW.BROADCAST_ADDR, channel, iface, lmk) {}
  // Destructor of the class
  ~ESP_NOW_Broadcast_Peer() {
    remove();
  // Function to properly initialize the ESP-NOW and register the broadcast peer
  bool begin() {
    if (!ESP_NOW.begin() || !add()) {
      log_e("Failed to initialize ESP-NOW or register the broadcast peer");
      return false;
    return true;
  // Function to send a message to all devices within the network
  bool send_message(const uint8_t *data, size_t len) {
    if (!send(data, len)) {
      log_e("Failed to broadcast message");
      return false;
    return true;
/* Global Variables */
uint32_t msg_count = 0;
// Create a broadcast peer object
ESP_NOW_Broadcast_Peer broadcast_peer(ESPNOW_WIFI_CHANNEL, WIFI_IF_STA, NULL);
/* Main */
  Serial.println("Testing");
  // Initialize the Wi-Fi module
  WiFi.mode(WIFI_STA);
  WiFi.setChannel(ESPNOW_WIFI_CHANNEL);
  while (!WiFi.STA.started()) {
    delay(100);
  Serial.println("ESP-NOW Example - Broadcast Master");
  Serial.println("Wi-Fi parameters:");
  Serial.println("  Mode: STA");
  Serial.println("  MAC Address: " + WiFi.macAddress());
  Serial.printf("  Channel: %d\n", ESPNOW_WIFI_CHANNEL);
  // Register the broadcast peer
  if (!broadcast_peer.begin()) {
    Serial.println("Failed to initialize broadcast peer");
    Serial.println("Reebooting in 5 seconds...");
    delay(5000);
    ESP.restart();
  Serial.println("Setup complete. Broadcasting messages every 5 seconds.");
  // Broadcast a message to all devices within the network
  char data[32];
  snprintf(data, sizeof(data), "Hello, World! #%lu", msg_count++);
  Serial.printf("Broadcasting message: %s\n", data);
  if (!broadcast_peer.send_message((uint8_t *)data, sizeof(data))) {
    Serial.println("Failed to broadcast message");
  delay(5000);
to enable the serial monitor select Tools > USB CDC On Boot > Enabled
That did it. Thanks!
Will ESP-NOW be suitable for remote control applications? Like for example, I want to control an RC car. Is the delay low enough for real time control?
depends on environment and distance - the range of WiFi is limited, e.g. 10metres
I haven't found a good example for BLE. I assume that should give me some 100ft range?
I have found BLE range to be very limited - in some application to less than a few feet
look at LoRa, HC-12, etc
EDIT: as this post has a solution and you have a new problem maybe worth opening a new post, e.g. "Will ESP-NOW be suitable for remote control applications? "
