I am currently working on a Zero-based I2S output guitar effects pedal.
This is the circuit diagram. This doesnt include a wire that was added, linking from where Radd3/Radd4 combine, to A5 to measure the output.
When I upload the following code, there is no output to the serial monitor.
#include <I2S.h>
I2S.begin(I2S_PHILIPS_MODE, 44100, 8);
if (!I2S.begin(I2S_PHILIPS_MODE, 44100, 8)) {
SerialUSB.println("Failed to initialize I2S!");
while (1); // do nothing
int input = 0;
int output = 0;
analogReference(AR_DEFAULT); // Set Reference to 3.3V (Default on Zero)
analogReadResolution(8); // Set Bit-depth to 8 (required for use of measurement on coolterm)
pinMode(A3, INPUT); // Set input pins
pinMode(A5, INPUT);
pinMode(0, LOW); // Set pin 0 to output 0V so that FS is always outputting to one side
int input = analogRead(A3);
int buff = 0;
buff = I2S.available(); // I2S buffer data size
int I2Ssample[buff]; // Buffer
for (int i = 0; i <= buff; i++) {
I2Ssample[i] = analogRead(A3); //populate buffer
I2S.write(I2Ssample, buff);
delayMicroseconds(1);
int output = analogRead(A5);
Serial.println(input);
It is being run at 8-bit because I had been using coolterm to record the serial data, so that I could create a plot of it in MATLAB.
I know that the serial connection is fine because when I upload the following simplified sketch, I can accurately monitor the input:
#include <I2S.h>
analogReadResolution(16);
I2S.begin(I2S_PHILIPS_MODE, 44100, 16);
I2S.begin(I2S_PHILIPS_MODE, 16);
pinMode(A3, INPUT);
pinMode(0, HIGH);
int in = analogRead(A3);
int out = analogRead(A5);
I2S.write(in);
delayMicroseconds(10);
SerialUSB.println(out); //can be changed to monitor in
With this sketch, there is no audio output (output from DAC stays at around 37500/1.9V +-noise) but a measurable guitar input, implying that there is a problem with the code. But with the first sketch I cant actually diagnose where the issue is due to not having the serial monitor/plotter.
Any help with the serial monitor issue or the code would be greatly appreciated.
Thanks!
