Serial Monitor requires reset to connect
I have seen various messages around this point, but none really solving my problem.
I create a very basic sketch with Serial.begin and Serial.println("Hello").
After downloading, the Serial Monitor remains empty.
  • Now, if I press the Arduino board hard reset, bingo ! I get my "Hello".
  • Issue is specific to R4 Minima (works fine with older R4)
  • I'm using IDE 2.3.4, and same behaviour if IDE is running on MacOS or Ubuntu...
Not critical (now I found the 'reset trick'), but painful...
Any feedback is welcome !
Not sure this is relevant, but it is necessary on some Arduinos, and IIRC, R4 Minima is one of those.
In setup(), after
Serial.begin();
try adding:
while(!Serial);
This will make setup() wait until the Serial instance is valid.
Noy sure what your problem is. Some boards start with residual data in the Serial buffer, some don't start right away and both benefit from a press of the reset button. Be a Willow tree not a Walnut tree.
Yep ! The 'while(!Serial)' seems to solve my problem.
Many thanks !
