Serial monitor stops showing data. Rf receiver (RC-Switch)
In my current project, I have a garage door opener sending codes to a 433 MHz RF receiver. While the program is running, if I press any of the 4 buttons on the remote, the serial monitor shows the correct "rfscene", from 0-3.
After a little while however, several seconds/inputs. The serial monitor stops showing data altogether, no matter how often/slow/long/short I press the remote button.
Code below, please advise if you have a suggestion.
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
int rfscene = 0;
int rfDelay;  //used to delay how often rfscene is output to serial monitor
  mySwitch.enableReceive(0);  // Receiver on interrupt 0 => that is pin #D2
  if (mySwitch.available()) {
    unsigned long int rfvalue = mySwitch.getReceivedValue();
    //Serial.print(rfvalue);
    switch(rfvalue){
      case 11302456: mySwitch.disableReceive();
                     rfscene = 0;
      case 11302449: mySwitch.disableReceive();
                     rfscene = 1;
      case 5408930: mySwitch.disableReceive();
                     rfscene = 2;
      case 11302450:mySwitch.disableReceive();
                     rfscene = 3;
    Serial.print(rfscene);
    rfDelay=millis();
    while(millis()<rfDelay+500){}
    mySwitch.resetAvailable();
Where do you find RCSwitch.h?
It's rc-switch.
That works well, it receives the data from the rf remote fine. Just after a certain time or certain amount of data, it stops.
It dies at 66 tries... 33 seconds... search for a timeout?
[edit]
You are overflowing this int
unsigned long rfDelay;
