Serial parseInt comments
I am using the bellow test code to verify Serial parseInt function and having the following issues:
  1. parseInt will skip leading zeroes in Serial buffer - example if buffer = TEST0012300 than
lcd_i2c.print((int) Serial.parseInt());
will print "12300"
  1. paresInt can skip a character - per doc. But it suppose to parse ( read / output) only int(s) so in theory it should skip ALL other characters anyway - per Stream class parseInt function definition which defaults to SKIP_ALL
  2. After adding "skip character" as a parameter , the compiler outputs this message
In file included from C:\Documents and Settings\Vaclav\Local Settings\Application Data\Arduino15\packages\arduino\hardware\sam\1.6.4\libraries\Wire/Wire.h:27:0,
from PAL_15_NEW_START.ino:40:
C:\Documents and Settings\Vaclav\Local Settings\Application Data\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino/Stream.h: In function 'int main()':
C:\Documents and Settings\Vaclav\Local Settings\Application Data\Arduino15\packages\arduino\hardware\sam\1.6.4\cores\arduino/Stream.h:95:8: error: 'long int Stream::parseInt(char)' is protected
long parseInt(char skipChar); // as above but the given skipChar is ignored
In file included from PAL_15_NEW_START.ino:124:0:
C:\DOCUME~1\Vaclav\LOCALS~1\Temp\build792391424716958793.tmp\sketch\AAA_Main.h:135:46: error: within this context
lcd_i2c.print((int) Serial.parseInt('c'));
Error compiling.
When including the "skip" parameter the parseInt fails because is now (?) protected.
Compiler reports error, which is "ignored" , but the code won't compile.
My conclusion - use parseInt with care.
  char  SerialBuffer[256];
  do
    // test serial int
    while (!Serial.available());
    while (Serial.available())
      lcd_i2c.clear();
      lcd_i2c.print(__func__);
      lcd_i2c.setCursor(0, 1);
      lcd_i2c.print((int) Serial.parseInt("1")); // fails compilation
      lcd_i2c.print((int) Serial.parseInt());     // skips leading zeroes in serial buffer
      for (;;);
      //while (lcd_i2c.print((int) Serial.parseInt() != 0 ));
      //      lcd_i2c.setCursor(0, 2);
      // return number of characters in SerialBuffer
      lcd_i2c.print(Serial.readBytes(SerialBuffer, 3));
      //      lcd_i2c.setCursor(0, 3);
      //      lcd_i2c.print(Serial.print(SerialBuffer[0]));
      // print buffer
      for (int i = 0; i  != 3; i++)
        lcd_i2c.print(SerialBuffer[i]);
      //      //for (;;);
      lcd_i2c.setCursor(16, 3);
      lcd_i2c.print(__LINE__);
      delay(DELAY);
      delay(5000);
      lcd_i2c.clear();
  } while (true);
  for (;;);
will print "12300"
It does not skip them. They simply don't mean anything.
The documentation is wrong.
Nonsense. It parses longs.
Well, once again, you've jumped to the wrong conclusion. Clearly, the error is NOT ignored. Unlike what most of us do to your posts...
