Serial port with Processing
I have uploaded this sketch into the arduino:
    pinMode(2, INPUT);
    Serial.println(analogRead(2));
and the analog pin is connected to the arduino's 5v, which means in the serial port it has to show only numbers around 1023.
though i have tried to read serial data from processing, it gives me numbers lower than 60. here is the processing code:
import processing.serial.*;
Serial myPort;
int val;
  String portName = Serial.list()[1]; //com3, same as arduino
  myPort = new Serial(this, portName, 9600);
void draw()
  if ( myPort.available() > 0)  // If data is available,
    val = myPort.read();         // read it and store it in val
    println(val);
what can cause this problem?
When you write from the arduino you are sending several ASCII bytes. When you read from processing you are only reading one byte.
See:- http://www.arduino.cc/playground/Interfacing/Processing
I'm having a problem with this line:
import cc.arduino.*;
the code says "The package "cc" does not exist. You might be missing a library"
although I have downloaded the library for firmata v1 into the processing libraries folder
anyone knows what is the problem now ?
You must have the hierarchy:
/libraries//library/.jar
best
thanks very much, that helped.
Don't know if you solved your original problem, but as Grumpy said it's because you're sending 2 bytes at a time when you send an int value...
Here is a method of sending and receiving int values that works for me:
Arduino:
Serial.print(0xff, BYTE); // Sync byte
Serial.print((val >> 8) & 0xff, BYTE);
Serial.print(val & 0xff, BYTE);
Processing:
while (port.available() >= 3) {
    if (port.read() == 0xff)
      val = (port.read() << 8) | (port.read());
zdroshnya, thank you very much, this is the hint I needed.
The problem of the normal arduino installation is the name of the file.
It is written "Arduino.jar" and so, I've got every time this error message.
I have renamed the file in "arduino.jar" and the library works well.
The guys of the arduino project should corred this in the "processing-arduino-0017.zip" file.
thanks a lot
Helmut
