Serial.print dispalys wrong format
I try to execute a scetch for my Ard.Uno, based on a tutorial example.
Here's the link to the example Serial.read() - Arduino Reference
Here's the code.
int incomingByte = 0;   // for incoming serial data
int incomread = 0;
        Serial.begin(9600);     // opens serial port, sets data rate to 9600 bps
        // send data only when you receive data:
        if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.available();
                incomread = Serial.read();
                // say what you got:
                Serial.print("I received: ");
                Serial.println(incomread, DEC);
But when I enter any character my Ser.monitor it doesn't displays them in a proper way - see attach. It looks like SM perceives it as ASCII character?
It is the ASCII code for that character. If you want to see the actual character then cast the variable to a (char).
Give this code a try and, in the Serial monitor at the bottom, select "No line ending" as the option for the first textbox.
int incomread = 0;
char c;
//    incomingByte = Serial.available();
//    incomread = Serial.read();
    c = Serial.read();
//    Serial.print(incomread, DEC);
    Serial.println(c);
The difference is the read() method returns a byte and I want to interprete it as a char, not an int. If you have the Newline option selected, it treats the '\n' as a character appended to the character you did enter...two bytes, not one. This would cause the prompt to be printed a second time followed by the newline character. However, since the newline is non-printing, all you see is the prompt.
Try Serial.write(). Your current code tells Serial.println() to print a number (char, int, long are all numbers) and hence it does that.
Delta_G:
No it doesn't. It returns an int.
Interesting. The doc says:
Returns
the first byte of incoming serial data available (or -1 if no data is available) - int
I think they could have stated it a little more clearly.
Thank you everybody, especially econjack for the explanation and a piece of code. It works now!
econjack:
It returns a int so you can tell the difference between 0xFFFF (-1) and 0x00FF ('ÿ'). If you use .available() properly you don't need to detect the -1 and can store the return value in a byte/char.
