I'm a new Arduino user working through the Arduino Projects. I'm currently on Project 3.
Line 12 of the code is Serial.print("Sensor Value: ");
The issue is that when I run the code I do not see this message, or any others. I expected to see it in a command prompt window on the PC that is connected by USB to the Arduino board.
I have tried this using the code from the Files/Examples/StarterKit, so I don't think mine is a code error.
The code contains under Setup, Serial.begin(9600);
The Arduino board seems to be working fine. Project 3 is displaying LEDs showing the temperature just like it should.
I have tried manually opening a command prompt window, and closing all windows except for the Arduino window.
My PC is running windows 10.
Thanks for any suggestions.
