Serial.print int divided with dot
Hi, I would print on a TFT little screen a number separated with dot. For example:
1234567 -> 1.234.567
Can someone help me?
Thank
Doesn't Google work where you are?
Sorry I cannot answer that as I do not know what type of number you are talking about. A float will normally print that way, an int will not.
You could hack your way to it, like so...
  uint32_t num = 1234567;
  Serial.print(num / 1000000);
  Serial.print(".");
  num = num % 1000000;
  Serial.print(num / 1000);
  Serial.print(".");
  Serial.println(num % 1000);
Gives 1.234.567 in serial monitor
Update Edit:
@stevetdr
The above doesn't work properly with numbers containing zero's
This solves that issue
char numStr[10];
uint32_t num;
void numToStr () {
  ultoa(num, numStr, 10);
  uint8_t len = strlen(numStr);
  for (uint8_t n = 1; n <= len; n ++) {
    Serial.print(numStr[n - 1]);
    if (n != len && (len - n) % 3 == 0) Serial.print(".");
  randomSeed(analogRead(0));
  num = random(1000000, 100000000);
  Serial.println(num);
  numToStr();
Try it in Wokwi...
With all your suggestion I solved the problem. Thank
Tested, perfect. I programmed a pesonal loooooooong program. Your is best and, I suppose, fastest. Thank again.
