I have a Plusivo ESP2866 development board.
I want to try out project 16 (Control an LED from web), but using the EXACT SAME CODE, instead of a normal text output, it gives me this (as an example): �HQʸ>dIY�4Cl�$`A�l$hr�9���
Code:
Credits: www.plusivo.com
Lesson 16: Control an LED from web
The code below is created for the lesson "Control an LED from web"
where you will connect to a WiFi network and host a simple website.
The code consists of 3, main, custom functions used to connect to the
WiFi ( "connectToWiFi()"), to setup the server ("setupServer()"),
and a function that sends a message to the browser ("htmlIndex()");
Also we defined a new function to control the led.
#include <ESP8266WebServer.h>
const char* ssid = "Square's iPhone";
const char* password = "(my password)";
//create a new object ESP8266WebServer
//the parameter "80" represent the port that the board listens to.
//if you use a port different than 80, you need to be sure you access it
//correctly from the browser.
//For example:
//if the ip is 100.32.12.39 and the port is 2093, you have to access
//the following address: "100.32.12.39:2093"
ESP8266WebServer server(80);
//the int variable "LED" stores the pin used by the LED
const int LED = D6;
String storage = "";
//the page variable is used to store the message sent to the
//user
//below you can find the html page
//more details about the html page can be found in the guide
String page =
R"(
<html lang='en'>
<head>
<title>Play with an LED</title>
<meta name='viewport' content='width=device-width, initial-scale=1'>
<link rel='stylesheet' href='https://use.fontawesome.com/releases/v5.1.0/css/all.css'/>
<link rel='stylesheet' href='https://stackpath.bootstrapcdn.com/bootstrap/4.1.2/css/bootstrap.min.css'/>
<script src='https://code.jquery.com/jquery-3.3.1.min.js'></script>
<style>
.css_on
color: orange;
.css_off
color: black;
</style>
</head>
<body>
<div class='container-fluid text-center'>
<div class='row text-center'>
<div class='col-sm-12' style='color:red;font-size:7vh'>
<p>Let's play with a bulb.</p>
</div>
</div>
<div class='row'>
<div class='col-sm-12'>
<i id='id_bulb' class='fas fa-lightbulb css_off' style='font-size:25vh'></i>
</div>
</div>
<br>
<div class='row'>
<div class='col-sm-12' style='font-size:7vh'>
<p>Click the button:</p>
</div>
</div>
<div class='row'>
<input type='button' class='btn btn-primary' id='id_button' value='Off' style='font-size:7vh'>
</div>
</div>
</div>
<script>
$(document).ready(function(){
$('#id_button').click(function(){
var current_state = $("#id_bulb").hasClass("css_off");
if(current_state == true)
$.ajax({
url:'/led',
type: 'POST',
data: {state: "On"},
$("#id_button").val("On");
$("#id_bulb").removeClass("css_off").addClass("css_on");
$.ajax({
url:'/led',
type: 'POST',
data: {state: "Off"},
$("#id_button").val("Off");
$("#id_bulb").removeClass("css_on").addClass("css_off");
</script>
</body>
</html>
//the led() function is used to turn On and Off the LED
void led()
//server.arg(name) returns the value (as string) of the argument "name"
storage = server.arg("state");
//if the value returned is "On", we will turn On the LED
//else, we will turn Off the LED
if(storage == "On")
//turn On the LED
digitalWrite(LED, HIGH);
//turn Off the LED
digitalWrite(LED, LOW);
//send a message to the user
server.send(200,"text/html", "ok");
//the htmlIndex() is called everytime somebody access the address
//of the board in the browser and sends back a message.
void htmlIndex()
//send the message to the user
server.send(200, "text/html", page);
//connectToWiFi() is used to connect to the WiFi network
//using the SSID and PASSWORD variables created at the
//beginning of the code
void connectToWiFi()
Serial.print("Connecting to the WiFi");
//set the WiFi mode to WiFi_STA.
//the WiFi_STA means that the board will act as a station,
//similar to a smartphone or laptop
WiFi.mode(WIFI_STA);
//connect to the WiFi network using the ssid and password strings
WiFi.begin(ssid, password);
//below we check the status of the WiFi and wait until the
//board is connected to the network
Serial.print("Waiting for connection");
Serial.print(".");
//when the board is successfully connected to the network,
//display the IP assigned to it in the serial monitor.
Serial.println("");
Serial.print("wrConnected to ");
Serial.println(ssid);
Serial.print("IP address: ");
//setupServer() function is used to set up and organise
//the website
void setupServer()
//the method "server.on()" is to call a function when
//the user access the location
//the default location is "/"
server.on("/", htmlIndex);
server.on("/led", led);
//start the server
server.begin();
//print in Serial Monitor that the HTTP server is started
Serial.print("HTTP server started");
//the following instruction initialise the pin stored in the
//variable motorspeed_pin(also the variable direction_pin) as OUTPUT
//this intruction lowers the impedance of the pin so it can provide
//a higher current to other components.
pinMode(LED, OUTPUT);
//start the Serial communication at 115200 bits/s
//wait 1 s until the Serial communication is started
//call the two functions used to connect connect to wifi
//and setup the server
connectToWiFi();
setupServer();
//wait 4 s for the server to start
delay(4000);
//the method below is used to manage the incoming requests
//from the user
server.handleClient();
What is it encoded with I don't know, but I sure can't read it!
