Finally I found it out. It is a very subtle bug in MsTimer2:
ISR(TIMER2_OVF_vect) {
#if defined (__AVR_ATmega168__) || defined (__AVR_ATmega48__) || defined (__AVR_ATmega88__) || defined (__AVR_ATmega328P__) || (__AVR_ATmega1280__)
TCNT2 = MsTimer2::tcnt2;
#elif defined (__AVR_ATmega128__)
#elif defined (__AVR_ATmega8__)
#endif
MsTimer2::_overflow();
If you remove the macros and only look at mega168 then you get
What is going on here? The library runs timer2 with a prescaler of 64. Thus the timer will tick with 250 kHz. So every 250 ticks an interrupt must be triggered to achieve the desired rate of one interrupt per millisecond. Instead of using CTC mode the library uses "normal mode". Thus the timer will process 256 ticks between to interrupts but it should use only 250. In order to compensate for this the ISR will advance TCNT2 immediately to the value of MsTimer2::tcnt2; which happens to be 6.
If TCNT2 == 0 at the start of the ISR, then of course this is equivalent to skipping 6 ticks. The result is the desired delay. However if TCNT2 > 0 at the start of the ISR, then it will skip less ticks. In the most extreme case TCNT2 == 255 setting it to 6 would result in 249 additional ticks instead of 6 skipped ticks.
But why is this an issue if I use Serial.print??? In order to find out I disassembled my compiled code. Here is what I found:
22c: 1f 92 push r1 cycles: 2 total: 2
22e: 0f 92 push r0 cycles: 2 total: 4
230: 0f b6 in r0, 0x3f ; 63 cycles: 1 total: 5
232: 0f 92 push r0 cycles: 2 total: 7
234: 11 24 eor r1, r1 cycles: 1 total: 8
236: 2f 93 push r18 cycles: 2 total: 10
238: 3f 93 push r19 cycles: 2 total: 12
23a: 4f 93 push r20 cycles: 2 total: 14
23c: 5f 93 push r21 cycles: 2 total: 16
23e: 6f 93 push r22 cycles: 2 total: 18
240: 7f 93 push r23 cycles: 2 total: 20
242: 8f 93 push r24 cycles: 2 total: 22
244: 9f 93 push r25 cycles: 2 total: 24
246: af 93 push r26 cycles: 2 total: 26
248: bf 93 push r27 cycles: 2 total: 28
24a: ef 93 push r30 cycles: 2 total: 30
24c: ff 93 push r31 cycles: 2 total: 32
24e: 80 91 1b 01 lds r24, 0x011B cycles: 2 total: 34
252: 90 91 1c 01 lds r25, 0x011C cycles: 2 total: 36
256: 80 93 b2 00 sts 0x00B2, r24 cycles: 2 total: 38
#endif
25a: 0e 94 d7 00 call 0x1ae ; 0x1ae <_ZN8MsTimer29_overflowEv>
So MsTimer2 takes 38 cpu cycles + ISR trigger overhead till it can set TCNT2. So everything that delays the MsTimer2 ISR for more than 24 cpu cycles will drag it down.
Looking into the serial ISR I find
000004b8 <__vector_19>:
#elif defined(USART0_UDRE_vect)
ISR(USART0_UDRE_vect)
#elif defined(USART_UDRE_vect)
ISR(USART_UDRE_vect)
#endif
4b8: 1f 92 push r1 cycles: 2 total: 2
4ba: 0f 92 push r0 cycles: 2 total: 4
4bc: 0f b6 in r0, 0x3f ; 63 cycles: 1 total: 5
4be: 0f 92 push r0 cycles: 2 total: 7
4c0: 11 24 eor r1, r1 cycles: 1 total: 8
4c2: 2f 93 push r18 cycles: 2 total: 10
4c4: 3f 93 push r19 cycles: 2 total: 12
4c6: 5f 93 push r21 cycles: 2 total: 14
4c8: 6f 93 push r22 cycles: 2 total: 16
4ca: 7f 93 push r23 cycles: 2 total: 18
4cc: 8f 93 push r24 cycles: 2 total: 20
4ce: 9f 93 push r25 cycles: 2 total: 22
4d0: af 93 push r26 cycles: 2 total: 24
4d2: bf 93 push r27 cycles: 2 total: 26
4d4: ef 93 push r30 cycles: 2 total: 28
4d6: ff 93 push r31 cycles: 2 total: 30
if (tx_buffer.head == tx_buffer.tail) {
4d8: 20 91 a1 01 lds r18, 0x01A1 cycles: 2 total: 32
4dc: 30 91 a2 01 lds r19, 0x01A2 cycles: 2 total: 34
4e0: 80 91 a3 01 lds r24, 0x01A3 cycles: 2 total: 36
4e4: 90 91 a4 01 lds r25, 0x01A4 cycles: 2 total: 38
4e8: 28 17 cp r18, r24 cycles: 1 total: 39
4ea: 39 07 cpc r19, r25 cycles: 1 total: 40
4ec: 31 f4 brne .+12 ; 0x4fa <__vector_19+0x42> cycles: 1-2 total: 41-42
// Buffer empty, so disable interrupts
#if defined(UCSR0B)
cbi(UCSR0B, UDRIE0);
4ee: 80 91 c1 00 lds r24, 0x00C1
4f2: 8f 7d andi r24, 0xDF ; 223
4f4: 80 93 c1 00 sts 0x00C1, r24
4f8: 16 c0 rjmp .+44 ; 0x526 <__vector_19+0x6e>
cbi(UCSRB, UDRIE);
#endif
else {
// There is more data in the output buffer. Send the next byte
unsigned char c = tx_buffer.buffer[tx_buffer.tail];
4fa: e0 91 a3 01 lds r30, 0x01A3 cycles: 2 total: 44
4fe: f0 91 a4 01 lds r31, 0x01A4 cycles: 2 total: 46
502: ef 59 subi r30, 0x9F ; 159 cycles: 1 total: 47
504: fe 4f sbci r31, 0xFE ; 254 cycles: 1 total: 48
506: 20 81 ld r18, Z cycles: 1 total: 49
tx_buffer.tail = (tx_buffer.tail + 1) % SERIAL_BUFFER_SIZE;
508: 80 91 a3 01 lds r24, 0x01A3 cycles: 2 total: 51
50c: 90 91 a4 01 lds r25, 0x01A4 cycles: 2 total: 53
510: 01 96 adiw r24, 0x01 ; 1 cycles: 2 total: 55
512: 60 e4 ldi r22, 0x40 ; 64 cycles: 1 total: 56
514: 70 e0 ldi r23, 0x00 ; 0 cycles: 1 total: 57
516: 0e 94 f0 03 call 0x7e0 ; 0x7e0 <__divmodhi4> cycles: 2 total: 59 + time for the subroutine
51a: 90 93 a4 01 sts 0x01A4, r25 cycles: 2 total: 61
51e: 80 93 a3 01 sts 0x01A3, r24 cycles: 2 total: 63
#if defined(UDR0)
UDR0 = c;
522: 20 93 c6 00 sts 0x00C6, r18 cycles: 2 total: 65
UDR = c;
#else
#error UDR not defined
#endif
526: ff 91 pop r31 cycles: 2 total: 67
528: ef 91 pop r30 cycles: 2 total: 69
52a: bf 91 pop r27 cycles: 2 total: 71
52c: af 91 pop r26 cycles: 2 total: 73
52e: 9f 91 pop r25 cycles: 2 total: 75
530: 8f 91 pop r24 cycles: 2 total: 77
532: 7f 91 pop r23 cycles: 2 total: 79
534: 6f 91 pop r22 cycles: 2 total: 81
536: 5f 91 pop r21 cycles: 2 total: 83
538: 3f 91 pop r19 cycles: 2 total: 85
53a: 2f 91 pop r18 cycles: 2 total: 87
53c: 0f 90 pop r0 cycles: 2 total: 89
53e: 0f be out 0x3f, r0 ; 63 cycles: 1 total: 90
540: 0f 90 pop r0 cycles: 2 total: 92
542: 1f 90 pop r1 cycles: 2 total: 94
544: 18 95 reti cycles: 4 total: 98
Obviously 98 is greater than 24 and I did not even count the cycles used inside of "call 0x7e0 ; 0x7e0 <__divmodhi4>".
In order to verify my hypthesis I replace MsTimer2 with the following code:
ISR(TIMER2_COMPA_vect) {
process_one_sample();
void initTimer2() {
// Timer 2 CTC mode, prescaler 64
TCCR2B = (1<<WGM22) | (1<<CS22);
TCCR2A = (1<<WGM21);
// 249 + 1 == 250 == 250 000 / 1000 == (16 000 000 / 64) / 1000
OCR2A = 249;
// enable Timer 2 interrupts
TIMSK2 = (1<<OCIE2A);
Yeah!!! Now only 30ppm deviation. This is within the expected tolerance of the crystal. Bug understood and fixed
I will contact the author of the library to fix this for the whole community.
One afterthought: I do not like to have ISR driven serial output. But now matter if this is a good idea or not, the library is full with code like
int i = (unsigned int)(buffer->head + 1) % SERIAL_BUFFER_SIZE;
Since the Arduino does have no hardware division this is very costly both in terms of CPU and memory. A much better way to wrap a counter is:
int i = (unsigned int)(buffer->head);
i = i<SERIAL_BUFFER_SIZE-1? i+1: 0;
