So I am running code to operate a few servo motors, and things weren't working correctly so I began to debug it.
The line:
Serial.print("In Do loop.\n");
Prints out as:
In D
After the line doesn't print correctly, the program stops entirely. So my partners and I thought that was weird so we were hoping someone here has seen something like this before. Any thoughts?
I'm going to upload the code in 3 parts as it's individually much more than 9000 characters.
//Things to do:
//1) Write function to ensure that arm is within 2 degrees of theta1, theta2, theta3.
#include <math.h>
#include <Servo.h>
Servo baseServo; //Motor that pivots entire arm. [2]
Servo servo1; //First joint motor. [3]
Servo servo2; //Second joint motor. [7]
Servo servo3; //Third joint/hand motor. [8]
Servo servo4; //Hand swivel motor. [9]
Servo servo5; //Claw open/close motor. [10]
double fin_ang1 = 0.0; //Stores value of actual angle of motor 1 from algorithm calculation.
double fin_ang2 = 0.0; //Stores value of actual angle of motor 2 from algoirthm calculation.
double fin_ang3 = 0.0; //Stores value of actual angle of motor 3 from algoirthm calculation.
double fin_ang2_math = 0.0; //Stores value of angle of motor 2 from algoirthm calculation (This is relative to vertical NOT actual motor angle).
double fin_ang3_math = 0.0;//Stores value of angle of motor 3 from algoirthm calculation (This is relative to vertical NOT actual motor angle).
int parallel_algo = 0; //When moveArm function is called, 0 represents parallel calculation, 1 represents values pulled from algorithm calculation.
//Stores the feedback values for each motor.
int feedback_1;
int feedback_2;
int feedback_3;
int feedback_4;
int feedback_5;
int feedback_0; //Base motor.
//Feedback pin assignments.
int feedback_pin1 = 1;
int feedback_pin2 = 2;
int feedback_pin3 = 3;
int feedback_pin4 = 4;
int feedback_pin5 = 5;
int feedback_pin0 = 0; //Base motor.
//Feedback pin angles calculated from best fit linear regressions.
double feedback_angle1;
double feedback_angle2;
double feedback_angle3;
double feedback_angle4;
double feedback_angle5;
double feedback_angle0;
//Stores lengths of each arm (in cm).
double D1 = 5.0;
double D2 = 6.0;
double D3 = 19.0;
//Stores the values of the angles.
double ang1 = 90.0;//Stores the actual value of the angle. This goes to the motor.
//This also stores the vertical value as it's independent of other joints.
double ang2 = 0.0;//Stores the value of angle 2 according to the diagram.
double ang2r = 0.0;//Stores the real value of angle 2. This goes to the motor.
double ang3 = 0.0;//Stores the value of angle 3 according to the diagram.
double ang3r = 0.0;//Stores the real value of angl3 3. This goes to the motor.
double angBase = 0.0;//Stores the angle of the base.
double angHand = 5.0; //Default value (5 degrees).
double angWrist = 0.0; //Angle of the wrist.
double oldAng1 = 90; //Stores old value of angle1.
double oldang2r = ang2r; //Stores old value of actual angle2.
double oldang3r = ang3r; //Stores old value of actual angle3.
double oldbaseAngle = 0.0; //Stores old value of the actual base angle.
//Xdn and Ydn are the coordinates of the location
//of the base of the arm. Dx and Dy store the location of point
//D which is located at (0,0) and represents the endpoint of
//the arm where it terminates at the origin. Ax and Ay store the
//new location of the base of the arm.
double Xdn = 0.0;
double Ydn = 0.0;
//Stores the CURRENT location of the base of the arm.
double Xd = 0.0;
double Yd = 0.0;
//Stores the value of the new coordinates to move to.
double newX, newY, newZ;
double Axn, Ayn;
double loopcode = 2; //Since I2c hasn't yet been implemented, if loopcode is 2, the loop() section of the code
//will function only when loopcode is 2.
double theta2;
double theta1;
double theta3;
Serial.begin(9600); //Allowing there to be serial monitor output.
/***Pin Assignments***/
baseServo.attach(2); //Base Servo
servo1.attach(3); //motor 1
servo2.attach(7); //motor 2
servo3.attach(8); //motor 3
servo4.attach(9); //swivel
servo5.attach(10); //claw
OpenCloseHand(0); //if 0, goes to 5 degrees. If 1, goes to 60 degrees.
do
moveToDefault();
}while (compareAngles(40,75,10,90)==false);
Serial.print("\n**Asking for input**\n");
calculateCurrentBaseLocation();
//do
enterCoordinates();
// } while (inRange() == false);
calculateXYProjection();
algorithm(Xdn, Ydn);
parallel_algo = 1;
moveArm();
void loop() //Runs over and over. This is why I have loopcode
//set to 2 initially and then set to a different value so it won't run over and over.
while (loopcode == 2)
do
enterCoordinates();
parallel_algo = 1;
moveArm();
loopcode = 1;
//This function moves the arm.
void moveArm()
feedback(); //Calculating feedback.
//From feedback values, set feedback angles to old values.
oldang2r = feedback_angle2;
oldAng1 = feedback_angle1;
oldang3r = feedback_angle3;
oldbaseAngle = feedback_angle0;
//If parallel, set values of angles TO move to.
if (parallel_algo == 0) //Parallel angles.
ang2r = ang2 + ang1 - 90; //Real value of angle of joint 2.
ang3 = 180 - ang1;
ang3r = ang3 + ang1 - ang2r; //Real value of angle of joint 3.
//If non parallel values and algorithm used, set values of angles TO move to.
if (parallel_algo == 1) //Non parallel angles. Values pulled from algorithm.
ang2r = fin_ang2;
ang1 = fin_ang1;
ang3r = fin_ang3;
//If non parallel values and algorithm not used, values are already set from setup or loop function.
if (parallel_algo == 2) //Non parallel angles. Values pulled directly from manually setting
//the values of the angles from the setup() or loop() functions.
//Set incremental movement of servo. Still need to make this more efficient.
double servo1Dir = abs(oldAng1 - ang1) / 100;
double servo2Dir = abs(oldang2r - ang2r) / 100;
double servo3Dir = abs(oldang3r - ang3r) / 100;
double baseDir = abs(oldbaseAngle - angBase) / 100;
//If movement of angles is in negative direction, set them to be -1 x their value.
if (ang1 < oldAng1)
servo1Dir *= -1;
if (ang2r < oldang2r)
servo2Dir *= -1;
if (ang3r < oldang3r)
servo3Dir *= -1;
if (angBase < oldbaseAngle)
baseDir *= -1;
Serial.print("**Moving servo 1**\n");
Serial.print("Moving from ");
Serial.print(oldAng1);
Serial.print(" to ");
Serial.print(ang1);
Serial.print("\n");
Serial.print("**Moving servo 2**\n");
Serial.print(oldang2r);
Serial.print(ang2r);
Serial.print("\n");
Serial.print("**Moving servo 3**\n");
Serial.print(oldang3r);
Serial.print(ang3r);
Serial.print("\n\n");
double i = oldAng1, j = oldang2r, k = oldang3r, l = oldbaseAngle;
//Begin process of moving by checking conditions of if any of the motors are not within .001 of their desired end point, it will keep moving until
//they all are. May be possible point of contention for the code to where it "spazzes" because it may fall outside of the range and continue moving.
while ((abs(i - ang1) > .001) || (abs(j - ang2r) > .001) || (abs(k - ang3r) > .001) || (abs(l - angBase) > .001))
if (abs(i - ang1) > .001)
servo1.write(i);
i += servo1Dir;
if (abs(j - ang2r) > .001)
servo2.write(j);
j += servo2Dir;
if (abs(k - ang3r) > .001)
servo3.write(k);
k += servo3Dir;
if (abs(l - angBase) > .001)
baseServo.write(l);
l += baseDir;
delay(30);
feedback(); //Diagnostic purposes.
void OpenCloseHand(int i)
if (i == 0)
servo5.write(5);
if (i == 1)
servo5.write(60);
void rotateWrist(double myAng)
feedback();
double inc = 10;
double delay_value = 100;
double dirMove = abs(myAng - feedback_angle4) / 20;
angWrist = feedback_angle4;
if (dirMove <= 1)
delay_value /= .5;
Serial.print("**Wrist Rotation**\n");
Serial.print("Rotating to angle ");
Serial.print(myAng);
Serial.print(" from angle ");
Serial.print(feedback_angle4);
Serial.print("\nMoving by ");
Serial.print(dirMove);
Serial.println("");
if ((myAng <= 180) && (myAng >= 0))
if (myAng < angWrist)
for (int i = angWrist; i > myAng; i -= dirMove)
Serial.print(i);
Serial.print(" ");
servo4.write(i);
delay(delay_value);
if (myAng > angWrist)
for (int i = angWrist; i < myAng; i += dirMove)
Serial.print(i);
servo4.write(i);
delay(delay_value);
Serial.print("**Done Moving**\n\n");
feedback();
Serial.println("Error. Not in range.");
Anytime you are using floating point constants in an expression, use decimal notation (e.g., 2.0, not 2) in the expression. Also, division is a relative slow operation so expression like where you divide a bunch of numbers by 9900 would be slightly more efficient if you multiplied by .00010101.
