Serial.print(Value,HEX);
HI,
I wanted to test the serial.print(value,HEX) function to make sure, that the output from the routine always are 2 chars long ( eg: 0x00 --> 00 and 0xFF --> FF).
so I wrote the following test code:
int n;
for (int n = 0; n <= 16; n++)
Serial.print(n,HEX);
But the result(s) were not very amusing:
n = 0 --> 0 (* 1 char ) , ... n = 9 --> 9 ( 1 char ),
n = 10 --> A (
1 char ) , n =15 --> F ( 1 char *)
the foreleading ZERO is missing.
n = 16 --> 10 ( 2 chars)
In a way the function is working fine but I want the output AS:
0 --> 00 , 1 --> 01, ... 9 --> 09 .... all with a foreleading Zero.
Is there an option in this ser.prnt(Value,HEX) command so I can force 2 digits output (eg a foreleading ZERO when value is below 0x10 ?
or is there another way to get a 2 (ASCII) chars output.
Kristian AKA snestrup2016
If you do Serial.print(n, DEC);, do you get a leading zero or zeroes?
So what's the problem?
(It's very simple to add as many leading zeroes as you desire, it just takes a tiny bit of effort)
Try snprintf with a 0x specifier, or Serial.print a 0 if the value is less than 16.
If you do not know snprintf, use Google, Bing, or equivalent.
vaj4088:
I tried Google() and Bing() and they didn't work.
Perhaps this:
int n;
    Serial.print("0x");
    Serial.print(n < 16 ? "0" : "");
    Serial.print(n, HEX);
    Serial.print(" ");
HI,
AWOL :
Sorry, my fault: I should have specified that the purpose of the test was to find IF I could use the ser.prnt(Value,hex) function in my project. My (very) old ISA-486 Compaq shortcircuited in the PSU and killed my EPROM-burner (Sunshine 4c). Now I have 4 * 2716 EPROM's I MUST read (and later copy that HEX-string to FLASH-RAM). SO I plan to build a new-EPROM-READER using an 2650 MEGA and was testing IF the ser.prnt(Value,hex) function was useful. (later putting the HEX-results into an Intel HEX string and later transfer that to a PC using puTTY or another FILE -supporting monitor. Sad to say - but using the ser.prnt(... DEC) option is not considered very useful, as it gives me more work on the PC-side.
HI,
econjack:
Thanks a lot. Your code did the job. As written in my answer (above) it is crucial that
the data are correct. With your code they are . ALL of them..
Many many thanks
(Pseudo-kode: BEGIN )
For (N = 0; n < No Ending; n++)
Serial.print("MANY MANY THANKS ");
(Pseudo-kode: Stop !)
Snestrup2016
aarg:
You didn't implement them properly, then. POST YOUR CODE. 8)
Bing worked great for me, with 157,000 (!) hits for snprintf. The very first hit (http://www.cplusplus.com/reference/cstdio/snprintf/)
was quite helpful.
Of course, the solution by econjack works as well. In fact, it looks a lot like
Good Luck!
