That is interesting but , when i counting a x variable , it gives wrong values. But when i add a serialprintln(x) , it is giving me normal values. Without serialprint , x counts unstable. Sometimes slow sometimes fast. :![]()
Same thing for the ultrasonic sensor. I have to print distance to get normal values.
Is always serial print harmful for Arduino? Because i will plug an adaptor to work Arduino and it will work maybe months like that.
while (digitalRead(led) == HIGH) {
  not bekleme++;
  bekleme = 0;
  say++;
  x = 2 + say /160 ;
  tamburcap = 106; //cm
  cap = 13.55;   //mm
  istenilen = 9999;
  long duration , distance;
  long durationt , distancet;
  digitalWrite(trigpin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigpin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echopin, HIGH);
  distance = duration / 58.2;
 // Serial.println(distance);
  Serial.println(x);
  if (timerRunning == 0 && distance < 10) {
   t = 0;
   tektur = ((pi * tamburcap * 1 * pi * (cap / 10) * (cap / 10) * 7.8) / 4000);
   tur = sayac + 1;
   y = (60 * pi * (tamburcap / 100)) / x;
   digitalWrite (ledPin, HIGH);
   not say++;
   eventtime1 = millis();
  Â
   Serial.println(kilo);
   if (y < 40) {
   interval = 2 + (eventtime1 - eventtime2) / 1000;
    timerRunning = 1;
    if (interval >= 10 && interval < 60 ) {
     sure = 7;
     sur = sur + sure;
     ortsur = sur / (tur);
     v = (60 * pi * (tamburcap / 100)) / sure;
     kilo = ((pi * tamburcap * (tur ) * pi * (cap / 10) * (cap / 10) * 7.8) / 4000) ; // pi.d^2 /4 yaptık ve gr sonucunu kiloya çevirdik
     total = total + v;
     ortalama = total / tur;
     esp.println("AT+CIPSTART=\"TCP\",\"" + ip + "\",80");
     delay(100);
     String sar = "GET http://" + ip + "/esp8266/postAnlık.php?Hammadde=-&Miktar=" + String(kilo) + "kg&Hizi=" + String(v) + "m/dk&TurSüresi=" + String(interval) + "";
     esp.print("AT+CIPSEND=");
     esp.println(sar.length() + 2);
     esp.println("GET http://" + ip + "/esp8266/postAnlık.php?Hammadde=-&Miktar=" + String(kilo) + "kg&Hizi=" + String(v) + "m/dk&TurSüresi=" + String(interval) + "");
     delay(100);
     Serial.print("Haddehızı(m/dk):");
     sayac++;
    if (interval > 2 && interval < 10) {
     sur = sur + interval ;
     v = (60 * pi * (tamburcap / 100)) / interval;
     x = 2 + say / 160;
     total = total + v;
     sayac++;
     delay(100);
     // Serial.println(ortalama);
    while (distance < 10) {
     not say++;
     say = 0;
  else if (timerRunning == 1 && distance >= 10) {
   eventtime2 = millis();
   timerRunning = 0;
   digitalWrite (ledPin, LOW);
""here is my code. just a part because it is too long if its neccessary i can share. I can calculate the time between two cycle. I tried to use millis for eveywhere but my sensor goes crazy after that. So i count "x" and divide it to 160 in order to find a second .
I fixed the ultrasonic sensor by adding these :-
timerRunning = 1;
-: inside if(y<40) -
they were inside if (timerRunning == 0 && distance < 10) this before.
but my counter x is still doesnt work right.
