Serial.println() function prints infinite times in Serial Monitor
Why Serial Monitor keeps on printing one Serial.println() function infinite times? Can you look up the code and help me out.
// For checking slots
Serial.println("Booked Slots");
for(i=0;i<=2;i++)
  val[i]=digitalRead(place[i]);
  if(val[i]==1)
    Serial.println(i+1);
Can you post your code?(seems obvious, I know)
#include <LiquidCrystal.h>
#include <Servo.h>
// Servo Motor
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
// LCD
int contrast=100;
const int rs=12,en=11,d4=5,d5=4,d6=3,d7=2;
LiquidCrystal lcd(rs,en,d4,d5,d6,d7);
//IR sensor
int isObstacle1Pin=22;
int isObstacle2Pin=24;
int isObstacle3Pin=26;
int isObstacle4Pin=28;
int isObstacle5Pin=30;
int isObstacle1=0;
int isObstacle2=0;
int isObstacle3=0;
int isObstacle4=0;
int isObstacle5=0;
// Control time for Servo
unsigned long ServoStartTime;
const unsigned long ServoOnTime=3000;
// Slots
int count=0;
int i;
byte val[3];
const int place[3]={26,28,30};
  pinMode(isObstacle1Pin,INPUT_PULLUP);
  pinMode(isObstacle2Pin,INPUT_PULLUP);
  myservo.attach(9);
  Serial.println("---------------------------------------------");
  Serial.println("    Welcome to Smart Car Parking System");
  analogWrite(A0,contrast);
  lcd.begin(16,2);
  lcd.setCursor(0,0);
isObstacle1 = digitalRead(isObstacle1Pin);
isObstacle2 = digitalRead(isObstacle2Pin);
isObstacle3 = digitalRead(isObstacle3Pin);
isObstacle4 = digitalRead(isObstacle4Pin);
isObstacle5 = digitalRead(isObstacle5Pin);
lcd.setCursor(0,0);
lcd.print("Hello");
for(i=0;i<=2;i++)
  if(val[i]==1)
// For Entry Gate
if(isObstacle1 == HIGH)
 if(isObstacle3 && isObstacle4 && isObstacle5)
  myservo.write(90);
  ServoStartTime = millis();
  Serial.println("Entry gate opening");
  // lcd.setCurso(0,1)
  // lcd.print("Entry gate opening
  for (pos = 90; pos <= 180; pos += 1)
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
     while(isObstacle1 == HIGH)
  delay(3000);
  Serial.println("Please hold on gate is closing");
  for (pos = 180; pos >= 90; pos -= 1)
  Serial.println("Entry gate closed");
// For Exit Gate
else if(isObstacle2 == HIGH)
  Serial.println("Exit gate opening");
     while(isObstacle2 == HIGH)
  delay(3000);
  Serial.println("Exit gate closed");
ashishpandey:
The short answer is because that line of code is in loop() and loop() repeats indefinitely.
Without knowing what you would like to happen I can't suggest how you should change your program.
...R
PS ... If you use the AutoFormat tool it will make your code much easier to read - for you as well as us.
ashishpandey:
#include <Servo.h>
// Servo Motor
// LCD
int contrast=100;
//IR sensor
int isObstacle1=0;
int isObstacle2=0;
int isObstacle3=0;
int isObstacle4=0;
int isObstacle5=0;
// Slots
int count=0;
int i;
byte val[3];
  myservo.attach(9);
  lcd.begin(16,2);
  lcd.setCursor(0,0);
lcd.setCursor(0,0);
lcd.print("Hello");
for(i=0;i<=2;i++)
  if(val[i]==1)
// For Entry Gate
  myservo.write(90);
  delay(3000);
// For Exit Gate
  delay(3000);
tl;dr (hint)
