Serial read char to byte?
not sure about what to do here. For starters i modify Robin2 serial example to try and receive a char string and convert it to byte for storing ip address. my compiler complains about brace initializer and then cast from char* to byte.
The modified example code only has 4 new lines :
  strtokIndx = strtok(NULL, ",");
  byte IP_FROM_PC[4] = atoi(strtokIndx);     // convert this part to array of 4 bytes ip address
  Serial.print("IP ");
  Serial.println(IP_FROM_PC);
an example of the input i would send is "in this case"<command,0,0.0,192.192.192.192>
please help
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
// variables to hold the parsed data
char messageFromPC[numChars] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
boolean newData = false;
  Serial.println("This demo expects 3 pieces of data - text, an integer and a floating point value");
  Serial.println("Enter data in this style <HelloWorld, 12, 24.7>  ");
  recvWithStartEndMarkers();
  if (newData == true) {
    strcpy(tempChars, receivedChars);
    // this temporary copy is necessary to protect the original data
    //   because strtok() used in parseData() replaces the commas with \0
    parseData();
    showParsedData();
    newData = false;
void recvWithStartEndMarkers() {
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '<';
  char endMarker = '>';
  char rc;
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (recvInProgress == true) {
      if (rc != endMarker) {
        receivedChars[ndx] = rc;
        ndx++;
        if (ndx >= numChars) {
          ndx = numChars - 1;
      else {
        receivedChars[ndx] = '\0'; // terminate the string
        ndx = 0;
        newData = true;
    else if (rc == startMarker) {
      recvInProgress = true;
void parseData() {      // split the data into its parts
  char * strtokIndx; // this is used by strtok() as an index
  strtokIndx = strtok(tempChars, ",");     // get the first part - the string
  strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
  strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
  integerFromPC = atoi(strtokIndx);     // convert this part to an integer
  floatFromPC = atof(strtokIndx);     // convert this part to a float
void showParsedData() {
  Serial.print("Message ");
  Serial.println(messageFromPC);
  Serial.print("Integer ");
  Serial.println(integerFromPC);
  Serial.print("Float ");
  Serial.println(floatFromPC);
What do you expect
  byte IP_FROM_PC[4] = atoi(strtokIndx);     // convert this part to a byte ip address
to do, even if it worked ?
I also see that IP_FROM_PC is being declared locally in the parseData() function so printing it in another function will not work unless you pass it to the other funcction
UKHeliBob:
What do you expect
Sorry about that,
basically i want to change an ip address that will be stored in the EEPROM in an array of 4 bytes. I did not include the EEPROM code in the example sketch as i think i can handle that part. all i need "i think" is to be able to parse the specific chars into an array of 4 bytes.
I send <updateip,10.10.10.10> from serial and i need part 10.10.10.10 to be parsed into byte array. i dont need the integerPart or FloatFromPc and those parts can be ingnored for now.
My first question would be why convert to an array of bytes in the first place ? Where is the IP address coming from and how will it be used when loaded from the EEPROM later ?
UKHeliBob:
ip address will be coming from human input at serial port. I will be using the address to be stored in the EEPROM for Udp.beginPacket(); which accepts a char string or a ip address which is 4 bytes. i will simply be using it only for this purpose. since i cannot store a String object in the EEPROM i must think of something else. I'm open to different logic.
Also i realize my example of printing the byte array would not print the 4 byte ipaddres
But using Robin's code you haven't got a String object, you have an array of chars and that can be stored directly into EEPROM with one call to EEPROM.put()
UKHeliBob:
Interesting. Did i do this right? this would leave me with a null terminated c_str _EEPROM.PC_IP that can be stored in eeprom?
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
WiFiUDP Udp;
struct {
  char PC_IP[20];
} _EEPROM;
    parseData();
    showParsedData();
    newData = false;
  char rc;
    rc = Serial.read();
        ndx++;
          ndx = numChars - 1;
      else {
        ndx = 0;
        newData = true;
  strcpy(_EEPROM.PC_IP, strtokIndx);     // convert this part to a byte ip address
  Serial.println(_EEPROM.PC_IP);
  // Udp.beginPacket(_EEPROM.PC_IP, 80);
  //Udp.write("SOMETHING");
  //Udp.endPacket();
I cannot make any sense of your attempt to parse the input. Why does it expect a float, for instance ?
Try this as an example
char * input = "<updateip,10.10.10.10>";
byte ip[4];
  while (!Serial);
  char * ptr;
  ptr = strtok(input, ","); //skip until the comma
  for (int b = 0; b < 4; b++) //next 4 characters delimited by full stops
    ip[b] = atoi(strtok(NULL, "."));  //get chars and convert to byte
  for (int b = 0; b < 4; b++) //show the result
    Serial.print(ip[b]);
    Serial.print("\t");
UKHeliBob:
byte ip[4];
  while (!Serial);
  char * ptr;
    Serial.print("\t");
this is very helpful. my last attempt to collect chars into the char array for the eeprom worked "except for no null termination". i think my example was bad because its nothin like my program. my program does not use the floats or intFromPc variables sorry for the confusion. but looking at your example, i get it.
this part here is the most confusing part to me with the string tokens and atoi. the way you use the for loops really helped me visualize what i was trying to do. thanks!!!
Here is that broken into separate lines with comments
    char * value = strtok(NULL, "."); //get the next value as a char pointer
    ip[b] = atoi(value);  //convert char to integer and save to array
