serial.read
Hello,
I have added a simple serail sender and serial receive program.
When I receive serial data the val is set to zero.
if the ledPin is on, it will still be turned off during the serial data input.
The queston is: like a tip how to solve this problem
// Sender
const int potPin = A1;
unsigned int val = 0;
Serial2.begin(38400);
val = map ( analogRead(potPin),0,1023,0,255);
Serial2.write(highByte( val));
Serial2.write(lowByte(val));
delay(5);
// Receiver
const int ledPin = 42;
unsigned int highByte, lowByte;
int val = 0;
boolean newData = false;
//byte h = Serial.read();
//  highByte = Serial.read();
//int l = 0;
Serial.begin(38400);
pinMode(ledPin, OUTPUT);
if (Serial.available()){
   val = Serial.read();
   newData = true;
if (newData == true ){
    if (val >= 100){
         digitalWrite( ledPin, HIGH);
        newData = false;
      digitalWrite( ledPin, LOW);
      newData = false;
Where is your wiring schematic ?, are you using 2 arduino DUE boards ?
Yes I use two arduino boards ( from Arduino DUE board to Arduino DUE board )
Connection
Sender TX2 to Receiver RX0
,, RX2 to ,, TX0
,, Gnd to ,, Gnd
It won't work, you have to use Serial (RX/TX) to print on Serial Monitor and e.g. Serial1 for data exchange with Serial2 of the second board.
Ok, I changed port0 to port1 now it works. ( I had not thought here for a moment )
Thanks for the information.
Hello,
I still have a question if I removed IC10 from the arduino DUE slave and use RX0 and TX0 is it then possible to communicate between the Arduino due's. ( for master I want use RX2 and TX2 )
Keep RX (RX0) and TX(TX0) to communicate with the serial monitor.
You have Serial1 (RX1/TX1), Serial2(RX2/TX2), Serial3(RX3/TX3) and Serial4 (with 3 more lines of code) as hadware serial.
Ok thanks again for te information.
