Serial.readStringUntil not working consistently
I'm developing a simple program using the Adafruit RP2040 Feather, Raspbery Pi 4b and a rotary encoder, and for some reason I can't get the Serial.readStringUntil command to work consistently.
It will be hooked up to a RPi 4b via the USB serial port, but right now is running off of a Windows 10 box using Arduino IDE 2.3.3.
The idea is that a "0" will be sent to the Feather via serial and the feather returns "Yes" so that the Pi knows that it's ready and running.
The Pi will then send a count value, say "10" to the Feather, which reads it and figures out the counts from the encoder, and either sends back a "Done" or "Timeout" response so that the Pi can continue it's work.
When it works, here's how it should respond. Please note that I have put some additional Serial.println's for debugging purposes in the code, and all tests are done using the Arduino IDE Serial Monitor.
Sending a message of "0" returns:
0
Yes
Exactly as expected. I can do this many times in a row without it failing.
Sending a message of "10" returns:
10
10
Reading
Timeout
Again, exactly as expected.
Now regardless of what value I send next, "0" or some other number, it will hang and not respond. I think it's something in my code, but I just can't figure out what I'm missing.
Any ideas?
Thanks,
GWFAMI
#include <Arduino.h>
#include <RotaryEncoder.h>
#include <time.h>
#include <sys/time.h>
//Serial pins on feather
#define PIN_IN1 2
#define PIN_IN2 3
time_t start, end;
String inString = "";
String temp = "";
// Setup a RotaryEncoder with 4 steps per latch for the 2 signal input pins:
// RotaryEncoder encoder(PIN_IN1, PIN_IN2, RotaryEncoder::LatchMode::FOUR3);
// Setup a RotaryEncoder with 2 steps per latch for the 2 signal input pins:
RotaryEncoder encoder(PIN_IN1, PIN_IN2, RotaryEncoder::LatchMode::TWO03);
  inString = "";
  while (Serial.available() > 0) {
    inString = Serial.readStringUntil('\n');
    Serial.println(inString);
    if (inString.toInt() == 0) {
      Serial.println("Yes");
      inString = "";
    if (inString.toInt() > 0) {
      read();
      inString = "";
// Read the current position of the encoder and print out when changed.
void read() {
  static int pos = 0;
  int newPos = 0;
  int countTo = inString.toInt();
  bool exit = false;
  Serial.println("Reading");
  time(&start);
  while (!exit) {
    time(&end);
    encoder.tick();
    newPos = encoder.getPosition();
    if (pos != newPos) {
      Serial.println("newPos:");
      Serial.println(newPos);
      Serial.println(" direction:");
      Serial.println((int)(encoder.getDirection()));
      pos = newPos;
      time(&start);
      Serial.println(char(difftime(end, start)));
    if (difftime(end, start) > 5) {
      exit = true;
      Serial.println("Timeout");
    if (pos >= countTo) {
      exit = true;
      Serial.println("Done");
  inString = "";
Here are two really good links that should help you
try
#include <time.h>
#define PIN_IN1 2
#define PIN_IN2 3
int countTo;
time_t start, end;
  if (Serial.available() > 0) {
    countTo = Serial.parseInt();
    while (Serial.available() > 0) Serial.read();
    Serial.println(countTo);
    if (countTo == 0)Serial.println("Yes");
    else read();
void read() {
  static int pos = 0;
  int newPos = 0;
  time(&start);
  while (true) {
    time(&end);
    encoder.tick();
      pos = newPos;
      Serial.println(int(encoder.getDirection()));
      time(&start);
      return;
      return;
Thanks kolaha, that works. I'll look at the code differences and try figure out why your changes worked.
GWFAMI
