Quick question, Can I use an external power to power an arduino nano and a MG996 servo motor at the same time? I´d use a 5V-1A charger from the wall, connecting the positive side to the Vin of the arduino.
So there won't be any problem if I power the arduino using the 5V pin and at the same time powering the servo? I don't want to fry anything and I'm not really an expert with electronics.
Thank you!
Depending on the current draw of the servo and the real-world capabilities of you wall wart,
it could be possible to have the Arduino reset due to voltage breakdowns.
I doubt there will be any danger to the Nano by running it from the same supply.
I got my last Nano for €1.75, so the risk is pretty small anyway.
This is not a good idea. As Whandall says above, you probably won't damage the Nano, but the electrical noise generated by the servo motor will probably cause program malfunction.
