Hello everyone.
I have a bit of a problem with a piece of code i working with. I have a qt113 sensor which turns on and off when some touches it. I'm also moving a servo. I would like the both the touch and servos to run without interruption. The servo moves to 3 positions, and an led turns on when the touch sensor is touch.
here is what i have so far:
int potPin = 1;
int ledPin4 = 8;
byte val = 0;
int THRESHOLD = 5;
int statePin = LOW;
int ledPin6 = 8;
int ledPin3 = 5;
int ledPin = 2;
int servoPin = 14; // servo connected to digital pin 2
int myAngle; // angle of the servo roughly 0-180
int pulseWidth; // servoPulse function variable
pinMode(servoPin, OUTPUT); // sets pin 2 as output
pinMode(ledPin, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin6, OUTPUT);
pinMode(ledPin4, OUTPUT); // declare the ledPin as an OUTPUT
void servoPulse(int servoPin, int myAngle)
pulseWidth = (myAngle * 10) + 600; // determines delay
digitalWrite(servoPin, HIGH); // set servo high
delayMicroseconds(pulseWidth); // micro pause
digitalWrite(servoPin, LOW); // set servo low
delay(20);
// refresh cycle
{ val = analogRead(potPin);
if (val >= THRESHOLD) {
statePin = !statePin;
digitalWrite(ledPin4, statePin);
delay(150); // we have to make a delay to avoid overloading the serial port
digitalWrite(ledPin, HIGH);
myAngle = 10; // starts at 10º
for(int i=0; i<300; i++) // loops 50 times
servoPulse(servoPin, myAngle);
digitalWrite(ledPin, LOW); // sets the LED off
// waits for a second
// wk_2
digitalWrite(ledPin3, HIGH); // sets the LED on
myAngle = 90; // moves to 90º
digitalWrite(ledPin3, LOW); // sets the LED off
// wk_3
digitalWrite(ledPin6, HIGH); // sets the LED on
myAngle = 170; // then moves to 170º
digitalWrite(ledPin6, LOW); // sets the LED off
int touchPin = 3; // set this to the pin connected to the qt113
int potPin = 1;
int ledPin4 = 8;
byte val = 0;
int THRESHOLD = 5;
int DELAY = 6; // number of seconds between servo movements
int statePin = LOW;
int ledPin6 = 8;
int ledPin3 = 5;
int ledPin = 2;
int servoPin = 14; // servo connected to analog pin 0
void processTouch(){
// do something here when qt113 sensor touched
delay(20); // refresh cycle
void servoMove(int servo, int angle, int duration){
// move servo to given angle, wait for given duration in seconds
for(int i=0; i < duration * 50; i++) // loops 50 times number of seconds
servoPulse(servo, angle);
if(digitalRead(touchPin) == HIGH) //change to LOW depending on qt113 interface
processTouch();
void loop(){
servoMove(servoPin,10,DELAY); // wk_1: 10 degrees for DELAY seconds
servoMove(servoPin,90,DELAY); // wk_2: 90 degrees
servoMove(servoPin,170,DELAY); // wk_3: 170 degrees
thank you for your help...
The servo doesn't seem to want to move. It only pulses forward. I would like for it to move to 170(left) 90(middle), right(10). I need this go continuously, which the cap sensor is on. For example, while the cap sensor is working, the servo is moving every minute to a designated position. It could be at 170 one minute and the next minute it moves to 10.
Servo works...the initial code i posted moves the servo to the designated position. it is moving to either 170(left), 10(right), 90(middle)...There is a delay of 1 minute between each position, and movement to one of these 3 position. All i need is to have the cap sensor which by the way works with the last code you posted, working which the servo is active. hope this make sense.
Could you post the latest code you are trying and say what the servo does when you run the sketch (still not clear if it moves in one direction and stops, or doesn't move at all)
here's what i have so far: It includes the cap sensor, i am using a blinkM which fades when you touch the sensor. I also have an rgb led which changes color when the servo moves to a specific position. so if the servo moves to 90, the led turns blue, if it moves 170, it turns red, if it moves 10 it turns green.
#include "Wire.h"
#include "BlinkM_funcs.h"
int blinkm_addr = 0x10;
#define CALMED_HUE 200
int potPin = 1; // set this to the pin connected to the qt113
int ledPin9 = 13;
byte val = 0;
int THRESHOLD = 5;
int statePin = LOW;
//blink m imports
long red = 0;
long green = 0;
long blue = 0;
//LED Imports
int ledPin2 = 4;
int ledPin1 = 3;
int ledPin = 2;
{ BlinkM_begin();
BlinkM_setAddress(blinkm_addr);
byte rc = BlinkM_checkAddress(blinkm_addr);
if (rc == -1) {
Serial.println("rnno response");
else if (rc == 1) {
Serial.println("rnaddr mismatch");
BlinkM_stopScript(blinkm_addr);
BlinkM_fadeToHSB(blinkm_addr, CALMED_HUE, 0xff, 0xff);
BlinkM_setFadeSpeed(blinkm_addr, 0x10);
val = 0;
pinMode(ledPin2, OUTPUT); // blue
pinMode(ledPin1, OUTPUT); // green
pinMode(ledPin, OUTPUT); // red
//blink process
delay(20);
// refresh cycle
// wk_0
digitalWrite(ledPin6, HIGH); // sets the red LED on
digitalWrite(ledPin3, HIGH); // sets the red LED on
digitalWrite(ledPin1, HIGH); // sets the red LED on
myAngle = 90; // starts at 10º
if(digitalRead(potPin) == HIGH) //change to LOW depending on qt113 interface
processTouch();
digitalWrite(ledPin6, LOW); // sets the red LED off
digitalWrite(ledPin3, LOW); // sets the red LED off
digitalWrite(ledPin1, LOW); // sets the red LED off
// wk_1
digitalWrite(ledPin6, HIGH); // sets the blue LED on
digitalWrite(ledPin4, HIGH); // sets the blue LED on
digitalWrite(ledPin1, HIGH); // sets the blue LED on
myAngle = 10; // moves to 90º
processTouch();
digitalWrite(ledPin6, LOW); // sets the blue LED off
digitalWrite(ledPin4, LOW); // sets the blue LED off
digitalWrite(ledPin1, LOW); // sets the blue LED off
// wk_2
digitalWrite(ledPin6, HIGH); // sets the green LED on
digitalWrite(ledPin3, HIGH); // sets the green LED on
digitalWrite(ledPin, HIGH); // sets the green LED on
processTouch();
digitalWrite(ledPin6, LOW); // sets the green LED on
digitalWrite(ledPin3, LOW); // sets the green LED on
digitalWrite(ledPin, LOW); // sets the green LED on
Did the comment above apply to the code I posted yesterday or the code you just posted? Did you run the code as posted yesterday and did it move the servos?
The code you just posted looks like it will have problems because your touch processing delays 150ms. That is much to long between servo pulses.
If you are only using one or two servos, you may want to look at some of the code in the playground that drives the servos using an interrupt. I think the library is called ServoTimer1.
