Hi guys i had a question regarding servo android control, is there a way i could load code to ardunio such that if i wanted to change the angle to lets say 72 degrees, the servo rotates to that degree and stays there for x seconds, then has free range of motion once again
this is the code i have, its not my own but implemented
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
int motor = 0;
Serial.begin(9600); // initialize serial:
myservo.attach(9); // attaches the servo on pin 9 to the servo object
Serial.print("Arduino control Servo Motor Connected OK");
Serial.print('\n');
// if there's any serial available, read it:
while (Serial.available() > 0) {
// look for the next valid integer in the incoming serial stream:
motor = Serial.parseInt();
// do it again:
pos = Serial.parseInt();
// look for the newline. That's the end of your sentence:
if (Serial.read() == '\n') {
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
// print the three numbers in one string as hexadecimal:
Serial.print("Data Response : ");
Serial.print(motor, DEC);
Serial.print(pos, DEC);
//for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
//{ // in steps of 1 degree
// myservo.write(pos); // tell servo to go to position in variable 'pos'
// delay(15); // waits 15ms for the servo to reach the position
//for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
//val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
//val = map(val, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
//myservo.write(val); // sets the servo position according to the scaled value
//delay(15);
which works fine, but i wanted to modify it where, until i enter a degree through android, the servo has free range of motion but this code will hold the servo without range of motion.
once i change the degree, its held for x amount of seconds then free range of motion returns
