I've been trying during some weeks achieve and make that a common servo responds to a button and a potentiometer at once. I've used the part of code of Knob example with some adds but the servo only works with the pot and not obey the button related lines.
I would like to move the servo to 90 degrees after a push button . When it reaches that position it would be desirable to be able to perform fine tunnings with the pot. Ten degrees less , ten degrees more. As you may see,. I've include "While" control structure which should made the sketch works once the button had been pressed and stay there. If the button is pressed during this while loop the expresion buttonState and press becomes different "the whille loop" and the sketch should continue and make the servo return to 0. I don't know what else to try!!
Thanks!!
#include <Servo.h>
Servo myservo; // create servo object to control a servo
const int potpin = 0; // analog pin used to connect the potentiometer
const int servoPin = 9; // The number of the Servo pin
const int buttonPin = 5; // The number of the button
int val; // Variable to read the value from the analog pin
int buttonState = 0; // Variable
int press = 0;
pinMode (buttonPin, INPUT);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(0);
press = digitalRead (buttonPin); //read the digital state of buttonPin
if (press == HIGH); {
buttonState = 1;
myservo.write (90); // Sets the initial servo position
while (( buttonState == 1 ) && (press != HIGH)) // Potentimeter activated to perform fine positioning on servo
val = analogRead(potpin); // Reads the value of the potentiometer
val = map(val, 0, 1023, 80, 110); // "Scaled range" ???? to use it with the servo (this case between 80 and 110) ten less ten more
myservo.write(val); // Set the servo to the new adjusted position
delay(10); // waits for the servo to get there
myservo.write (0); // Returns the servo to its parking position from "while loop" exit
delay (100);
buttonState = 0; // Reset ButtonState to 0
I've made changes to the sketch and is working better. The pot respond to the tiny gap established by valAdj but the button is skipped . Of course I've already ckecked the connections and also I made a test with another button sketch and it is OK. The servo moves on start up to the expresion in "val" and then allow movements with the pot. Just on start up.
#include <Servo.h>
int val; // variable to read the value from the analog pin
int valAdj;
int press = 0;
val = 90;
myservo.write (val); // Sets the initial servo position
valAdj = analogRead(potpin); // range 0 - 1023 // Reads the value of the potentiometer
valAdj = valAdj >> 5; // divide by 32 range 0 - 31
valAdj = valAdj - 16; // range -16 - 15
val = val + valAdj;
delay(30); // waits for the servo to get there
[code/]
int valAdj;
int press = 0;
val = 90;
val = val + valAdj;
I've noted that that delay line is missing. I've included it but nothing happens now,... so,.. so far the sketch goes better without that line. I don't know . What else could be making the button not being working???
Try this version - study the changes I have made
#include <Servo.h>
int valAdj;
int press = 0;
// button code
val = 90;
// potentiometer code
val = val + valAdj;
// servo code
No Jacques. It doesn't. and as I said.. I also checked connections just in case. Other button sketchs runs fine. I'm going to try changing initial var values.
Let me see Jacques. I think no matther where is the pot on its course. The button is skipped
The pot part is working fine as I need, but the button seem not exist for this sketch. The value in val is only taken when the board is reset. I'd need the button takes the servo there first and... after another push, it returns to 0 or start position.
The value of variable "val" is the desired preset position (on the sketch) where... after first press, servo should move.
Yes,... Is the same after your previous question. And.. its very difficult to find the exact center of the pot
After the first push, the servo moves to the preset position and then... the pot should take control for fine adjustings in that range written by @Robin2 until another push that would make return the servo into a preset parking position. Maybe,.. I don't know......it may not be possible with a single button but the project requires only one.
I'll perform some testings... initializing that val variable.
Yes 90 degrees on first push.. and then the pot controls the servo for fine adjustments until a second push which should take it back to 0. If there's a third push it should take again the servo to 90 degrees and so on.
The desired positions for me are those written previously on the sketch and only can be changed until you upload another modified sketch!!
Then your switch has two states. Just like a toggle switch.
You will need a variable that will remember in which state it is. And you should initialise it with either 0 or 90.
When you read the switch, use that variable to decide what value to assign to "val". Also, remember to change the variable to it's new state.
byte currentState = 0;
if (currentState == 90) { val = 0; currentState = 0; }
else { val = 90; currentState = 90; }
EDIT: When you set val to 0, "valAdj" will bring the value of "val" in the negative zone if the potentiometer is below half point. You might use "currentState" to decide if you want "valAdj" to be added (or not). I modified the code so that currentState makes more sense.
Sincerely I got lost in this one. The sketch was uploaded like this and nothing happened. Excuse me!!
#include <Servo.h>
// int valAdj;
int press = 0;
// button code
if (currentState == 90){
val = 90;
currentState = 0;
currentState = analogRead(potpin); // range 0 - 1023 // Reads the value of the potentiometer
currentState = currentState >> 5; // divide by 32 range 0 - 31
currentState = currentState - 16; // range -16 - 15
val = val + currentState;
// servo code
delay(30);} // waits for the servo to get there
else {
val = 0;
currentState = 90;
Somehow, you thought that you should replace valAdj with currentState. valAdjust is used for the offset obtained by the pot. Don't touch it.
current State is only concerned with the state of the switch and to decide where the servo should go next.
This is what I had in mind:
#include <Servo.h>
int valAdj;
int press = 0;
// button code
if (press == HIGH){
if (currentState == 90){ //The toggle code I suggested
val = 0;
currentState = 0;
else {
val = 90;
currentState = 90;
valAdj= analogRead(potpin); // range 0 - 1023 // Reads the value of the potentiometer
if (currentState == 90) { //Decide if you want to add valAdj to val.
val = val + valAdj;
// servo code
Using the sketch like you sent, the pot works and the button doesn't
If I deactivate this two lines
// button code
if (press == HIGH) {
if (currentState == 90) { //The toggle code I suggested
val = 0;
currentState = 0;
else {
val = 90;
currentState = 90;
// if (currentState == 90) { //Decide if you want to add valAdj to val.
// val = val + valAdj;
// servo code
delay(30);
The button work and the pot doesn't.
Anyway thank you for your time. I'm a little ashamed to bother you!!. I think I have to use only a simple knob using the Knob example. Thank you!!
