Servo Does Not Name a type. WHY?????
I KEEP GETTING THE ERROR “SERVO DOES NOT NAME A TYPE” WHEN COMPILING! WHY?
#include <Servo.h>
//Pins
int PirF = 3;
int BootTime = 30;
int clearencemax = 5;
int mouth = 13;
int SonicFtrig = 41 ;
int SonicFecho = 40 ;
int piron = 0;
Servo RightServo;
Servo LeftServo;
RightServo.attach(8);
LeftServo.attach(7);
//Functions
void moveturn() {
//Full Turn Around
void movestop() {
LeftServo.write(90);
RightServo.write(90);
void moveforward() {
//Full speed ahead
void scanforlife() {
movestop();
piron = digitalRead(PirF);
if (piron= HIGH) {}
void speak() {
digitalWrite(mouth, HIGH);
//Put Emic Code here
void shootgun() {
//Shoot the water gun!
  //Warm up sensors
void setup(){
  pinMode(PirF, INPUT);
  digitalWrite(PirF, LOW);
//Booting stuff
  Serial.print("booting systems ");
    for(int i = 0; i < BootTime; i++){
      Serial.print(".");
    Serial.println(" done");
    Serial.println("ACTIVE");
    delay(50);
  //HCSR04 Stuff
 long duration, distance;
  digitalWrite(SonicFtrig, LOW);  // Added this line
  delayMicroseconds(2); // Added this line
  digitalWrite(SonicFtrig, HIGH);
//  delayMicroseconds(1000); - Removed this line
  delayMicroseconds(10); // Added this line
  duration = pulseIn(SonicFecho, HIGH);
  distance = (duration/2) / 29.1;
  if (distance < clearencemax) {
delay(10);
scanforlife();
else {
  moveforward();
HELP! PLEASE! WHAT IS WRONG???!!!
Your cap-lock key needs fixing.
Mark
These two lines need to be inside a function.
Delta_G:
OK, will try it and get back to you!
