Servo Hold Position with joystick input - Using Arduino / Programming Questions - Arduino Forum
yes thats the idea
I finally got a working code
here it is, but one problem I still have is the swing of the crane , the kids figured out how to swing the load by pushing the joystick left right to start a wrecking ball effect
was wondering how to put in a 1 sec delay before the opposite direction change happens
any help would be much appreciated
#include <Servo.h>
#define SERVO_X_PIN 2
#define SERVO_Y_PIN 3
#define JOYSTICK_X_PIN A0
#define JOYSTICK_Y_PIN A1
const long MIN_PULSE = 440;
const long MAX_PULSE = 2500;
const long MIN_POT = 0;
const long MAX_POT = 1200;
const long POWER_OF_TWO_TO_AVERAGE = 4;
const long SERVO_PULSE_RANGE = MAX_PULSE - MIN_PULSE; //
const long START_PULSE_X = MIN_PULSE + (SERVO_PULSE_RANGE / 2);
const long START_PULSE_Y = MIN_PULSE + (SERVO_PULSE_RANGE / 2);
const long POT_RANGE = MAX_POT - MIN_POT;
const int BUFFER_SIZE = 1 << POWER_OF_TWO_TO_AVERAGE;
const int BUFFER_LIMIT = BUFFER_SIZE - 1;
const unsigned long ANALOG_READ_PERIOD = 5000;
const unsigned long DEBUG_PERIOD = 100000;
const unsigned long SERVO_PERIOD = 20000;
const long LOW_CENTER_THRESHOLD = 565;
const long HIGH_CENTER_THRESHOLD = 580;
const long POT_TO_SPEED_CONSTANT = 55;
long averagingBufferX[BUFFER_SIZE];
long averagingBufferY[BUFFER_SIZE];
int bufferIndex = 0;
long servoPosition[] = {START_PULSE_X, START_PULSE_Y};
long bufferTotalX = 0;
long bufferTotalY = 0;
unsigned long lastDebug;
unsigned long lastServo;
unsigned long lastAnalogRead;
Servo myServo[2];
myServo[0].writeMicroseconds(START_PULSE_X);
myServo[1].writeMicroseconds(START_PULSE_Y);
myServo[0].attach(SERVO_X_PIN, MIN_PULSE, MAX_PULSE);
myServo[1].attach(SERVO_Y_PIN, MIN_PULSE, MAX_PULSE);
for (byte i; i < BUFFER_SIZE; i++)
averagingBufferX[i] = (MAX_POT - MIN_POT) / 2;
averagingBufferY[i] = (MAX_POT - MIN_POT) / 2;
bufferTotalX += averagingBufferX[i];
bufferTotalY += averagingBufferY[i];
lastDebug = micros();
lastServo = lastDebug;
lastAnalogRead = lastDebug;
checkAnalogReadTime();
void checkAnalogReadTime()
if (micros() - lastAnalogRead > ANALOG_READ_PERIOD)
lastAnalogRead += ANALOG_READ_PERIOD;
long joystickInputX = analogRead(JOYSTICK_X_PIN);
long joystickInputY = analogRead(JOYSTICK_Y_PIN);
bufferIndex++;
bufferIndex &= BUFFER_LIMIT;
bufferTotalX -= averagingBufferX[bufferIndex];
bufferTotalY -= averagingBufferY[bufferIndex];
averagingBufferX[bufferIndex] = joystickInputX;
averagingBufferY[bufferIndex] = joystickInputY;
bufferTotalX += averagingBufferX[bufferIndex];
bufferTotalY += averagingBufferY[bufferIndex];
checkServoTime();
void checkServoTime()
if (micros() - lastServo > SERVO_PERIOD)
lastServo += SERVO_PERIOD;
controlServo();
void controlServo()
long average[3];
long servoSpeed[3];
average[0] = bufferTotalX >> POWER_OF_TWO_TO_AVERAGE; // it might be a good idea to make averageX global so it can be used elsewhere in program
average[1] = bufferTotalY >> POWER_OF_TWO_TO_AVERAGE;
for (int i = 0; i < 2; i++)
if (average[i] < LOW_CENTER_THRESHOLD)
servoSpeed[i] = (average[i] - LOW_CENTER_THRESHOLD) / POT_TO_SPEED_CONSTANT;
else if (average[i] > HIGH_CENTER_THRESHOLD)
servoSpeed[i] = (average[i] - HIGH_CENTER_THRESHOLD) / POT_TO_SPEED_CONSTANT;
servoSpeed[i] = 0;
servoPosition[i] += servoSpeed[i];
if (servoPosition[i] > MAX_PULSE)
servoPosition[i] = MAX_PULSE;
else if (servoPosition[i] < MIN_PULSE)
servoPosition[i] = MIN_PULSE;
myServo[i].writeMicroseconds(servoPosition[i]);
checkDebugTime(average[0], average[1], servoPosition[0], servoPosition[1], servoSpeed[0], servoSpeed[1]);
void checkDebugTime(long averageX, long averageY, long servoOutputX, long servoOutputY, long speedX, long speedY)
if (micros() - lastDebug > DEBUG_PERIOD)
lastDebug += DEBUG_PERIOD;
Serial.print(F("average = "));
Serial.print(averageX, DEC);
Serial.print(F(", "));
Serial.print(averageY, DEC);
Serial.print(F(", Servo = "));
Serial.print(servoOutputX, DEC);
Serial.print(servoOutputY, DEC);
Serial.print(F(", Spead = "));
Serial.print(speedX, DEC);
Serial.println(speedY, DEC);
