Servo library wont work with radio head library
The servo works using the example code from its library but when I add code from the radio head library to control a 433mhz rf module it stops working, here is the code I am using
#include <PWMServo.h>
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
String  bar_state = "close"; //bar state open or close
String  prev_bar_state = "close";
String msgReicieved = "";//message from reiciver
const int servo_rotation = 180 ;//amount the servo needs to move to completly move bar
const int servo_pin = 9;
int pos = 0;    // variable to store the servo position
PWMServo Lock_servo;  // create servo object called "servo"
RH_ASK driver (2000,4,11,3);// (speed,riecieve,transmit,push to talk)
  Lock_servo.attach(SERVO_PIN_A);  // (pin 9)
    if (!driver.init())
         Serial.println("init failed");
  Serial.println("seffgdfg ");
  uint8_t buf[12];//amount of characters that is goign to be recieved
  uint8_t buflen = sizeof(buf);
  if (driver.recv(buf, &buflen)) {
    int i;
    // Message with a good checksum received, dump it.
    Serial.print("Message: ");
    msgReicieved = (char*)buf;
    Serial.println(msgReicieved);
  for(pos = 0; pos < 180; pos += 1) { // goes from 0 degrees to 180 degrees, 1 degree steps
    Lock_servo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1) {   // goes from 180 degrees to 0 degrees
when I delete these lines from the setup it starts working again
    if (!driver.init())
but those lines of code are needed to run the RF module, anyone know what is going on?
There is a library conflict over timer usage. You might try the ServoTimer2 library.
State which Arduino you are using, as there might be other solutions.
I am using arduino nano
There are about a half-dozen versions of "Arduino Nano", but I would guess you have the Classic Nano with the ATmega328. Try ServoTimer2.
I have the ATmega328P(old boot loader) if that changes anything
Okay I will try the servo timer 2
It worked thank you.
