Hey guys im having some trouble in coding a 360 motor. In my original 180 i could easily make it stop at two distant points then return to its original point. But I wanted to change it to a 360 and now when i do it using my original code it just keeps spinning. Can anyone help me with making it stop at two points and then return to its original position? Here my code.
#include <Servo.h>
#include <Wire.h>
Servo mainServo;
Servo servo1;
Servo servo2;
LiquidCrystal_I2C lcd(0x27, 16, 2);
const int selectButton = 2;
const int increaseButton = 3;
const int startButton = 4;
int selectedTime = 0; // 0 = hours, 1 = minutes, 2 = seconds
int countdownHours = 0;
int countdownMinutes = 0;
int countdownSeconds = 0;
bool lastSelectState = HIGH;
bool lastIncreaseState = HIGH;
bool lastStartState = HIGH;
int mainServoPos1 = 45;
int mainServoPos2 = 135;
int mainServoStart = 180;
mainServo.attach(9);
servo1.attach(10);
servo2.attach(11);
lcd.init();
lcd.backlight();
pinMode(selectButton, INPUT_PULLUP);
pinMode(increaseButton, INPUT_PULLUP);
pinMode(startButton, INPUT_PULLUP);
// Reset servo positions
mainServo.write(mainServoStart);
servo1.write(0);
servo2.write(0);
displayTimeSelection();
if (buttonPressed(selectButton, lastSelectState)) {
selectedTime = (selectedTime + 1) % 3; // Cycles between 0, 1, 2
if (buttonPressed(increaseButton, lastIncreaseState)) {
increaseTime();
if (buttonPressed(startButton, lastStartState)) {
startCountdown();
void increaseTime() {
if (selectedTime == 0 && countdownHours < 23) {
countdownHours++;
} else if (selectedTime == 1 && countdownMinutes < 59) {
countdownMinutes++;
} else if (selectedTime == 2 && countdownSeconds < 59) {
countdownSeconds++;
void displayTimeSelection() {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Set Time:");
lcd.setCursor(0, 1);
lcd.print(selectedTime == 0 ? "*H " : "H ");
lcd.print(countdownHours); // No leading zero
lcd.print(":");
lcd.print(selectedTime == 1 ? "*M " : "M ");
lcd.print(countdownMinutes); // No leading zero
lcd.print(":");
lcd.print(selectedTime == 2 ? "*S " : "S ");
lcd.print(countdownSeconds); // No leading zero
void startCountdown() {
lcd.clear();
lcd.print("Counting down...");
while (countdownHours > 0 || countdownMinutes > 0 || countdownSeconds > 0) {
printDoubleDigit(countdownHours);
lcd.print(":");
printDoubleDigit(countdownMinutes);
lcd.print(":");
printDoubleDigit(countdownSeconds);
if (countdownSeconds > 0) {
countdownSeconds--;
} else if (countdownMinutes > 0) {
countdownMinutes--;
countdownSeconds = 59;
} else if (countdownHours > 0) {
countdownHours--;
countdownMinutes = 59;
triggerServo();
void triggerServo() {
lcd.clear();
lcd.print("Dispensing...");
// Move main servo to position 1
mainServo.write(mainServoPos1);
delay(2000);
// Open and close first servo
servo1.write(90);
servo1.write(0);
// Move main servo to position 2
mainServo.write(mainServoPos2);
delay(2000);
// Open and close second servo
servo2.write(90);
servo2.write(0);
// Reset main servo to start position
delay(2000);
lcd.clear();
lcd.print("Done!");
bool buttonPressed(int button, bool &lastState) {
bool buttonGotPressed = false;
bool currentState = digitalRead(button);
if (currentState != lastState) {
if (currentState == LOW) {
buttonGotPressed = true;
lastState = currentState;
delay(50);
return buttonGotPressed;
// Helper function to print numbers as two digits (01, 02, ... 09)
void printDoubleDigit(int number) {
if (number < 10) {
lcd.print("0");
lcd.print(number);
