#include <Servo.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
Servo myservo;
#define ir_enter 2
#define ir_back 4
#define ir_car1 8
#define ir_car2 9
int S1 = 0, S2 = 0;
int flag1 = 0, flag2 = 0;
int slot = 2;
int RedLed=11;
int GreenLed=12;
pinMode(ir_car1, INPUT);
pinMode(ir_car2, INPUT);
pinMode(ir_enter, INPUT);
pinMode(ir_back, INPUT);
pinMode(RedLed, OUTPUT);
pinMode(GreenLed, OUTPUT);
myservo.attach(7);
myservo.write(90);
lcd.init();
lcd.backlight();
lcd.setCursor(2, 0);
lcd.print("A Final Year");
lcd.setCursor(0, 1);
lcd.print("Project By P.M");
delay(3000);
lcd.clear();
Read_Sensor();
int total = S1 + S2;
slot = slot - total;
Read_Sensor();
lcd.setCursor(0, 0);
lcd.print("Available slot:");
lcd.print(slot);
lcd.print(" ");
lcd.setCursor (0,1);
if (S1 == 1) {
lcd.print("S1:Fill ");
digitalWrite(GreenLed, LOW);
digitalWrite( RedLed, HIGH);
else {
lcd.print("S1:Empty");
digitalWrite(GreenLed, HIGH);
digitalWrite(RedLed, LOW);
lcd.setCursor (8,1);
if (S2 == 1) {
lcd.print("S2:Fill ");
digitalWrite(RedLed, HIGH);
else {
lcd.print("S2:Empty");
if (S1 == 1 && S2 == 1) {
else {
if (digitalRead (ir_enter) == 0 && flag1 == 0) {
if (slot > 0) {
flag1 = 1;
if (flag2 == 0) {
myservo.write(90);
slot = slot - 1;
lcd.setCursor (0,0);
lcd.print(" Sorry No Space! ");
delay(1500);
if (digitalRead (ir_back) == 0 && flag2 == 0) {
flag2 = 1;
if (flag1 == 0) {
myservo.write(90);
slot = slot + 1;
if (flag1 == 1 && flag2 == 1) {
myservo.write(90);
delay(1);
void Read_Sensor() {
S1 = 0, S2 = 0;
ssss
if (digitalRead(ir_car1) == 0) {
S1 = 1;
if (digitalRead(ir_car2) == 0) {
S2 = 1;
Revisa la batería.
Quita las 4 eses que te sobran en la función " void Read_Sensor() " para que compile y hombre, dile que se mueva algo porque siempre lo pones a 90º
Good day everyone.
I was using this code to run my project successfully, but after a while, i try to run it but the servo motor is not working. So i don't know if some can help me to fix this issue. Thank you.
Moderador:
Por favor, lee las Normas del foro .
Si estas en este foro no uses inglés para dirigirte porque eso solo debes usar si posteas en el foro en inglés.
Tampoco doble postees. Ya cerré el otro hilo similar a este.
Quedas advertido.
Supongo que tu Servo está usando Vcc de tu Arduino. Utilice una fuente de alimentación externa adecuada y conecte la fuente de alimentación externa Vcc a su Servo y conecte la fuente de alimentación externa GND al Arduino GND.
I am guessing your Servo is using Vcc from your Arduino. Use a suitable external power supply and connect the external power supply Vcc to your Servo and connect the external power supply GND to the Arduino GND.
¿Entienden que en esta sección del foro se publica en español?
Lo veo ahora (Esp). Estaba respondiendo a la publicación de OP # 4 en inglés.
Double post:
Moderadora
El otro hilo cerrado y el OP baneado hasta mañana por ser la primera vez.
Sorry sir. Double post is as result of network failure.
En dos secciones diferentes del foro y con 5 días de diferencia, no parece una falla de la red. ![]()
Moderador
A ver @badisaidriss supongo que se te escapó una vez mas.
Estas en el foro en Español ya no estas en el foro en inglés, donde supongo fuiste porque tu navegador te traduce automáticamente.
Asi que ahora solo usa español y lo enfatizo para que no te equivoques de nuevo.
