Servo Motor Twitching & Not Positioning Problem with HMI
I tried hardware serial. First, there was not any problem. But I have to add one IR sensor to my project. When I add it and send its data to screen continueously, same problem happened.
As you said, when the data is tranmitting or receiving over serial, servo signals are interfering.
In short, situation is same with previous. I should try alternative ways to complete my project.
If I write servo position and then close that part of software until the next servo positioning time, does it cause any problem?
Or I think to add some delays to seperate servo and serial signals. Can it be suitable? What do you think Jim?
I don't see IR in your code or diagram
Now, you need to post a wiring diagram of your entire circuit and complete code.
Please explain what this device is supossed to do.
Please give datasheets for all the components used
Intended schematic and purpose, please. Is that an IR sensor for a remote, or simply for a digital input? A library for a remote will play havoc with your interrupt allocations, unless you're careful; it can be done, but not with the defaults used.
I added IR sensor latestly to this code. At that time there was not.
I want to make a project to my little hobby car about autoshifting system with servos instead of manuel shifting with ropes. So I need some datas as engine rpm and car velocity together with servo controlling. Aim is this basically. I shared codes and wiring after adding IR. With this code, I cancelled software serial and added hardware serial. But servos are still twitching a little bit. If we compare with oldes software, it is a little improved but not fixed totally.
#include <Wire.h>
#include <EEPROM.h>
#include <Servo.h>
unsigned char Buffer[9];
unsigned char   vitesdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x50 , 0x00, 0x00, 0x00};
unsigned char   rpmdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x52 , 0x00, 0x00, 0x00};
boolean debounceDone;
unsigned long btnPressTime = 0;
int delayPeriod = 500;
int vites = 0;
byte servobirikideger;
byte servoucdortdeger;
int hafiza;
byte servobirikihafiza;
byte servoucdorthafiza;
Servo servobiriki;
Servo servoucdort;
char vitesekran[4];
//****************** RPM Tachometer Variables **************
const int IR_PIN = 3;  // IR sensor out pin is connected to arduino pin 2 which is interrupt pin
volatile unsigned int counter = 0;  // Counter variable for revolutions
unsigned long previousMillis = 0;  // Variable to store previous time
unsigned int rpm = 0;  // Variable to store RPM value
void setup(){
  pinMode(7,INPUT);
  pinMode(4,INPUT);
  pinMode(15,INPUT);
  delay(100);
  servobirikihafiza = EEPROM.read(5);
  servoucdorthafiza = EEPROM.read(6);
  servobiriki.write(servobirikihafiza);
  servoucdort.write(servoucdorthafiza);
  servobiriki.attach(5);
  servoucdort.attach(6);
  hafiza = EEPROM.read(0);
  vites = hafiza;
  pinMode(IR_PIN, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(IR_PIN), IRinterrupt, FALLING);
void loop(){
 // ************** Vites Sayici Bölüm *******
 if(millis() - btnPressTime > delayPeriod) debounceDone = true;
 if(digitalRead(7) == HIGH &&  vites<=3 && debounceDone == true)
   btnPressTime = millis();
   debounceDone = false;
   vites++;
   Serial.println(vites);
 if(digitalRead(4) == HIGH &&  vites>0 && debounceDone == true)
   vites--;
 if(digitalRead(15) == HIGH &&  vites>0 && debounceDone == true)
   vites = 0;
  // ********************* Servo Motor Pozisyonlama & Hafızaya - Ekrana Yazdırma Bölümü ************
 if( vites == 0)
   servobirikideger = 105 ;
   servobiriki.write(servobirikideger);
   servoucdortdeger = 110;
   servoucdort.write(servoucdortdeger);
   if (digitalRead(7) == HIGH || digitalRead(4) == HIGH || digitalRead(15) == HIGH)
     EEPROM.write(0,vites);
     EEPROM.write(5,servobirikideger);
     EEPROM.write(6,servoucdortdeger);
 if(vites == 1)
   servobirikideger = 134 ;
 if (vites == 2)
   delay(250);
   servobirikideger = 65 ;
 if (vites == 3)
   delay(400);
   servoucdortdeger = 69;
 if (vites == 4)
   servoucdortdeger = 137;
 //************** RPM Counter Area ****************
 if (currentMillis - previousMillis >= 1000)
    detachInterrupt(digitalPinToInterrupt(IR_PIN));
    rpm = (counter / 1) * 60;
    counter = 0;
     rpmdeger[6] = highByte(rpm);
     rpmdeger[7] = lowByte(rpm);
     Serial.write(rpmdeger, 8);
void IRinterrupt()
  counter++;
void Data_Arduino_to_Display()
 vitesdeger[6] = highByte(vites);
 vitesdeger[7] = lowByte(vites);
 Serial.write(vitesdeger, 8);
Try changing your IR pin to INPUT_PULLUP from INPUT
"like"? - was that the fix, then?
I liked your solution advice :). Thank you very much to you and other friends for your kind supports and advices.
Now I tried it. It is better than pullup. Problem was fixed almostly.
Only problems are tachometer calibration and servo's position parameters changing issue.
I added some parameters to Dwin and read them by arduino to adjust servo positions. Datas are coming normally. But sometimes somehow they are changing by themselve without any intervention by me. There can be noise or programming fault. I am trying to understand root cause.
I wanted to share my code's last state but it is too long now. May be not possible to evaluate by anybody to understand problem in here. But if you can check, I can share with you @camsysca
Share here, unless it doesn't fit(unlikely, would have to be VERY wordy, or super long).
Many eyes = faster, better solutions; some of us need to sleep sometimes, too.
Here is my code. Normally, my servos are being positioned between 0-180 degrees. I took position values from HMI according to my adjust. But sometimes some servo positions comes abnormal values like 2300, 1800 etc without my intervention by me. Problem is this.
#include <SoftwareSerial.h>
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
Servo servobir;
Servo servoiki;
unsigned long oldtime1 =0; //for data reading from dwin
unsigned long oldtime2 =0; // for data saving
unsigned long oldtime3 =0; // for gear counting
unsigned long oldtime4 = 0;// for servo control
unsigned long oldtime5 = 0; // for gear counting a int reset
unsigned long oldtime6 = 0; // for RPM writing to Dwin
unsigned long oldtime7 = 0; // for Speed writing to Dwin
//Write Buttons Variables
int servoyazdir = 0;
int sensoryazdir =0;
int tarlayazdir = 0;
int otomatikyazdir = 0;
//Dwin Datas Saving Addresses
int servobirnotr;
int servoikinotr;
int vitesbir;
int vitesiki;
int vitesuc;
int vitesdort;
int devirsensor;
int hizsensor;
int hidroliksensor;
int vitesartir;
int vitesazalt;
// Memory Addresses
int servobirnotrhafiza;
int servoikinotrhafiza;
int vitesbirhafiza;
int vitesikihafiza;
int vitesuchafiza;
int vitesdorthafiza;
int devirsensorhafiza;
int hizsensorhafiza;
int hidroliksensorhafiza;
int vitesartirhafiza;
int vitesazalthafiza;
//Data Write To Dwin Addresses
unsigned char   servobirnotrdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x70, 0x00, 0x00, 0x00};
unsigned char   vitesbirdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x71, 0x00, 0x00, 0x00};
unsigned char   vitesikideger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x72, 0x00, 0x00, 0x00};
unsigned char   servoikinotrdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x73, 0x00, 0x00, 0x00};
unsigned char   vitesucdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x74, 0x00, 0x00, 0x00};
unsigned char   vitesdortdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x75, 0x00, 0x00, 0x00};
unsigned char   devirsensordeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x56, 0x00, 0x00, 0x00};
unsigned char   hizsensordeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x57, 0x00, 0x00, 0x00};
unsigned char   hidroliksensordeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x58, 0x00, 0x00, 0x00};
unsigned char   vitesartirdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x90, 0x00, 0x00, 0x00};
unsigned char   vitesazaltdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x91, 0x00, 0x00, 0x00};
unsigned char   hizdeger[8] = {0x5a, 0xa5, 0x05, 0x82, 0x53 , 0x00, 0x00, 0x00};
unsigned char incomingdata[9];
unsigned int incomingdwin;
// Shift value + additional variables
int vites = 0;
int count1;
int count2;
boolean a = LOW;
boolean b = LOW;
boolean c = LOW;
// ********************** Engine RPM Measurement Variables *************************
  pinMode(15,INPUT); //shift + button
  pinMode(7,INPUT); // shift - button
  pinMode(4,INPUT); // shift notr button
  pinMode(9,INPUT); // Hand clutch input (D9)
  pinMode(12,OUTPUT); // Hand clutch relay (D12)
  vites = EEPROM.read(15);
  servobirnotrhafiza = EEPROM.read(0);
  vitesbirhafiza = EEPROM.read(1);
  vitesikihafiza = EEPROM.read(2);
  servoikinotrhafiza = EEPROM.read(3);
  vitesuchafiza = EEPROM.read(4);
  vitesdorthafiza = EEPROM.read(5),
  devirsensorhafiza = EEPROM.read(6);
  hizsensorhafiza = EEPROM.read(7);
  hidroliksensorhafiza = EEPROM.read(8);
  vitesartirhafiza = EEPROM.read(9);
  vitesazalthafiza = EEPROM.read(10);
  servobir.attach(5);
  servoiki.attach(6);
  servobirnotrdeger[6] = highByte(servobirnotrhafiza);
  servobirnotrdeger[7] = lowByte(servobirnotrhafiza);
  Serial.write(servobirnotrdeger, 8);
  vitesbirdeger[6] = highByte(vitesbirhafiza);
  vitesbirdeger[7] = lowByte(vitesbirhafiza);
  Serial.write(vitesbirdeger, 8);
  vitesikideger[6] = highByte(vitesikihafiza);
  vitesikideger[7] = lowByte(vitesikihafiza);
  Serial.write(vitesikideger, 8);
  servoikinotrdeger[6] = highByte(servoikinotrhafiza);
  servoikinotrdeger[7] = lowByte(servoikinotrhafiza);
  Serial.write(servoikinotrdeger, 8);
  vitesucdeger[6] = highByte(vitesuchafiza);
  vitesucdeger[7] = lowByte(vitesuchafiza);
  Serial.write(vitesucdeger, 8);
  vitesdortdeger[6] = highByte(vitesdorthafiza);
  vitesdortdeger[7] = lowByte(vitesdorthafiza);
  Serial.write(vitesdortdeger, 8);
  devirsensordeger[6] = highByte(devirsensorhafiza);
  devirsensordeger[7] = lowByte(devirsensorhafiza);
  Serial.write(devirsensordeger, 8);
  hizsensordeger[6] = highByte(hizsensorhafiza);
  hizsensordeger[7] = lowByte(hizsensorhafiza);
  Serial.write(hizsensordeger, 8);
  hidroliksensordeger[6] = highByte(hidroliksensorhafiza);
  hidroliksensordeger[7] = lowByte(hidroliksensorhafiza);
  Serial.write(hidroliksensordeger, 8);
  vitesartirdeger[6] = highByte(vitesartirhafiza);
  vitesartirdeger[7] = lowByte(vitesartirhafiza);
  Serial.write(vitesartirdeger, 8);
  vitesazaltdeger[6] = highByte(vitesazalthafiza);
  vitesazaltdeger[7] = lowByte(vitesazalthafiza);
  Serial.write(vitesazaltdeger, 8);
  //----- Engine RPM Parameter set up -------
  pinMode(IR_PIN, INPUT);          // using  internal pull up resistors of arduino as pin 2 interrupt is triggered on logic low (falling edge)
  // ************** Shift Counter Area *******
  if(millis() - btnPressTime > 250) debounceDone = true;
  if(digitalRead(7) == HIGH &&  vites<=3 && debounceDone == true && a == 0)
     vites++;
     a = 1;
     Serial.print("vites:");
  if(digitalRead(4) == HIGH &&  vites>0 && debounceDone == true && b == 0)
     vites--;
     b = 1;
  if(digitalRead(15) == HIGH &&  vites>0 && debounceDone == true && c == 0)
     vites = 0;
     c = 1;
 // ********************************** Servo Positioning ****************************
  if( vites == 0)
     servobir.write(servobirnotrhafiza);
     servoiki.write(servoikinotrhafiza);
       EEPROM.write(15,vites);
       Serial.print("Servobirpozisyon:");
       Serial.println(servobirnotrhafiza);
       Serial.print("Servoikipozisyon:");
       Serial.println(servoikinotrhafiza);
  if( vites == 1)
     servobir.write(vitesbirhafiza);
       Serial.println(vitesbirhafiza);
  if( vites == 2)
     delay(400);
     servobir.write(vitesikihafiza);
       Serial.println(vitesikihafiza);
  if( vites == 3)
     delay(400);
     servoiki.write(vitesuchafiza);
       Serial.println(vitesuchafiza);
  if( vites == 4)
     servoiki.write(vitesdorthafiza);
       Serial.println(vitesdorthafiza);
 if ( millis () - oldtime5 > 90 )
   if ( a == 1 && digitalRead(7) == LOW)
      a = 0;
   if ( b == 1 && digitalRead(4) == LOW)
      b = 0;
   if ( c == 1 && digitalRead(15) == LOW)
      c = 0;
    oldtime5 = millis();
 //********************* Engine RPM Calculation ************************************
 unsigned long currentMillis = millis();                 // only update rpm values after 1 sec interval
    detachInterrupt(digitalPinToInterrupt(IR_PIN));     // disable interrupt on pin 2 during this calculation because any comming interrupt on this moment will increment the counter and calculation result will change
    rpm = (counter / 1) * 60;  // Calculate RPM . use the value of pulses you get per revolution in your rotating object
    counter = 0;                                        // reset counter value after calculating rmp
    attachInterrupt(digitalPinToInterrupt(IR_PIN), IRinterrupt, FALLING);      // enable the interrupt again to start revolutions counting again
    Serial.print("RPM degeri:");
    Serial.println(rpm);
 //***************************  Speed Calculation (will be added later)***************************
 // *********** Hand Clutch Button Circuit (will be added later)***********************
 Dwin_to_Arduino();
 delay(10);
 Arduino_to_Dwin();
 delay(10);
void IRinterrupt()
{   // this inerrupt function is called whenever a falling edge is triggered on arduino pin 3
  counter++;           // incriment the revolutions counter on each interrupt
//********Data Reading From Dwin***********
void Dwin_to_Arduino()
 if(millis() - oldtime1 >200)
   if(Serial.available()>0)
     int i=0;
     while (Serial.available() > 0)
       char comingByte = Serial.read();
       delay(2);
       incomingdata[i] = comingByte;
       i++;
      if (incomingdata[3] == (byte)0x83)
       incomingdwin = (incomingdata[7]<<8) | incomingdata[8];
       Serial.println(incomingdwin);
      if (incomingdata[0] ==0x5A)
       switch(incomingdata[4])
          case 0x20:  //servo yazdir butonu
            if(incomingdata[8]==1)
              Serial.println("Servo ekranı yazdir butonu ON");
              servoyazdir = 1;
              Serial.println("Servo ekranı yazdir butonu OFF");
              servoyazdir = 0;
          case 0x21:  //sensör ekranı yazdir butonu
              Serial.println("Sensör ekranı yazdir butonu ON");
              sensoryazdir = 1;
              Serial.println("Sensör ekranı yazdir butonu OFF");
              sensoryazdir=0;
          case 0x22:  //tarla sayfası yazdir butonu
              Serial.println("Tarla ekranı yazdir butonu ON");
              tarlayazdir = 1;
              Serial.println("Tarla ekranı yazdir butonu OFF");
              tarlayazdir=0;
          case 0x23:  //otomatik vites on/off butonu
              Serial.println("otomatik vites butonu ON");
              otomatikyazdir = 1;
              Serial.println("otomatik vites butonu OFF");
              otomatikyazdir=0;
          case 0x60:  //Birinci servo nötr pozisyon ekrandan gelen parametre
            if(incomingdata[8]>=1)
              servobirnotr = incomingdwin;
          case 0x61:  //Vites bir pozisyon ekrandan gelen parametre
              vitesbir = incomingdwin;
          case 0x62:  //Vites iki pozisyon ekrandan gelen parametre
              vitesiki = incomingdwin;
          case 0x63:  //İkinci Servo nötr pozisyon ekrandan gelen parametre
              servoikinotr = incomingdwin;
          case 0x64:  //Vites üç pozisyon değeri
              vitesuc = incomingdwin;
          case 0x65:  //Vites dört pozisyon değeri
              vitesdort = incomingdwin;
          case 0x80:  //Devir sensor çarpan parametre değeri
              devirsensor = incomingdwin;
          case 0x81:  //Hiz sensor çarpan parametre değeri
              hizsensor = incomingdwin;
          case 0x82:  //hidrolik sensor parametre değeri
              hidroliksensor = incomingdwin;
          case 0x92:  //Vites artırma devri
              vitesartir = incomingdwin;
          case 0x93:  //Vites artırma devri
              vitesazalt = incomingdwin;
     memset(incomingdata,0,sizeof(incomingdata));
   oldtime1 = millis();
// ********Data write to Dwin from Arduino**************
void Arduino_to_Dwin()
  if(millis() - oldtime2 >200 && servoyazdir ==1)
    switch(servoyazdir)
      case 1:
       if(servoyazdir >0)
        if(servobirnotr >0 && servobirnotr < 180)
           servobirnotrhafiza = servobirnotr;
           EEPROM.write(0,servobirnotrhafiza);
           Serial.print("Servobirnotr hafizaya alınan deger:");
           servobirnotr = 0;
        if(vitesbir >0 && vitesbir < 180)
           vitesbirhafiza = vitesbir;
           EEPROM.write(1,vitesbirhafiza);
           Serial.print("Vitesbir hafizaya alınan deger:");
           vitesbir =0;
        if(vitesiki >0 && vitesiki < 180 )
           vitesikihafiza = vitesiki;
           EEPROM.write(2,vitesikihafiza);
           Serial.print("Vitesiki hafizaya alınan deger:");
           vitesiki = 0;
        if(servoikinotr >0 && servoikinotr < 180)
           servoikinotrhafiza = servoikinotr;
           EEPROM.write(3,servoikinotrhafiza);
           Serial.print("Servoikinotr hafizaya alınan deger:");
           servoikinotr = 0;
        if(vitesuc >0 && vitesuc < 180)
           vitesuchafiza = vitesuc;
           EEPROM.write(4,vitesuchafiza);
           Serial.print("Vitesuc hafizaya alınan deger:");
           vitesuc = 0;
        if(vitesdort >0 && vitesdort <180)
           vitesdorthafiza = vitesdort;
           EEPROM.write(5,vitesdorthafiza);
           Serial.print("Vitesdort hafizaya alınan deger:");
           vitesdort = 0;
      servoyazdir = 0;
    if(sensoryazdir >0)
      if(devirsensor >0 && devirsensor < 255)
       devirsensorhafiza = devirsensor;
       EEPROM.write(6,devirsensorhafiza);
       Serial.print("Devirsensor hafizaya alınan deger:");
       Serial.println(devirsensorhafiza);
       devirsensor = 0;
      if(hizsensor >0 && hizsensor < 255)
       hizsensorhafiza = hizsensor;
       EEPROM.write(7,hizsensorhafiza);
       Serial.print("hizsensor hafizaya alınan deger:");
       Serial.println(hizsensorhafiza);
       hizsensor = 0;
      if(hidroliksensor >0 && hidroliksensor < 255)
       hidroliksensorhafiza = hidroliksensor;
       EEPROM.write(8,hidroliksensorhafiza);
       Serial.print("hidroliksensor hafizaya alınan deger:");
       Serial.println(hidroliksensorhafiza);
       hidroliksensor = 0;
      sensoryazdir = 0;
    if(otomatikyazdir >0)
      if( vitesartir > 0 && vitesartir < 30)
       vitesartirhafiza = vitesartir;
       EEPROM.write(9,vitesartirhafiza);
       Serial.print("vitesartir hafizaya alınan deger:");
       Serial.println(vitesartirhafiza);
       vitesartir = 0;
      if( vitesazalt > 0 && vitesazalt < 30)
       if(vitesazalt < vitesartirhafiza)
         vitesazalthafiza = vitesazalt;
         EEPROM.write(10,vitesazalthafiza);
         Serial.print("vitesazalt hafizaya alınan deger:");
         Serial.println(vitesazalthafiza);
         vitesazalt = 0;
      otomatikyazdir = 0;
   oldtime2 = millis();
FIrst,
    switch(servoyazdir)
      case 1:
       if(servoyazdir >0)  //ALWAYS TRUE, because it's value is 1 or we wouldn't be here
The following won't always work, if you're still in the process of receiving characters
     int i=0;
       delay(2);
       i++;
Point is, you're NOT using the internal pullup. May or may not work, but comment isn't correct, so your logic may be flawed.
Without reading more carefully, I can't tell if your EEPROM usage is flawed, but it looks suspicious to me.
Chew on all that, fix what you can understand, and post a new copy and we'll have another peek at it.
Thank you for investigations @camsysca.
Acctually I copied some structures from another softwares or from another parts from this code directly with its comment. So comments can not be related with this part like this code. I deleted it now. :
switch(servoyazdir)
      case 1:
In previous code, I was using INPUT_PULLUP. So this explanation was related with this pullup. I forgot to delete it after replacing this input_pullup with input. So you can ignore it. I deleted it also now.
How can I make any correction in this code and EEPROM part camsysca? Should I make some delay or other things to supply always and proper work?
     int i=0;
       delay(2);
       i++;
