Hi, I am fairly new to Arduino and have not been able to find an answer to this problem.
Basically, I have modified the Servo Sweep example sketch so that I can control a servo motor from an android device, through bluetooth. I have it set up so that when I type in the value '0', '1', '2' or '3', the servo motor will move to a specified angle. I was wondering if it is possible to use an alternative to 'delay' so that I can interrupt the case '0'. At the moment I have to wait for the servo motor to finish moving before I can press another value.
Any help would be greatly appreciated, thanks.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9); // attaches the servo on pin 9 to the servo object
Serial.begin(9600); //begins serial communication
int pos;
if (Serial.available()){
delay(100);
while(Serial.available()>0){
pos=Serial.read(); //reads the value sent from Visual Basic
if(pos=='0'){
myservo.write(45);
myservo.write(0);
myservo.write(90);
myservo.write(135);
myservo.write(180);
myservo.write(90);
delay(1000);}
else if(pos=='1')
myservo.write(-90); //rotates the servo 90 degrees (right)
else if(pos=='2')
myservo.write(180); //rotates the servo 180 degrees (Left)
else if(pos=='3')
myservo.write(-180); //rotates the servo 180 degrees (right)
