Servo movements don't work in if() functions
Hello! I'm an arduino beginner, and I'm currently trying to write some code that basically moves a servo to a certain position based on the lowest of five distance variables. Here's the code:
  //Takes the minimum of all 5 distances to see which is closest
  int lowestVal = min(distance1, min(distance2, min(distance3, min(distance4, distance5))));
    //This entire code section only works if the lowest value is significant
    if(lowestVal < 800){
    //Depending on which sensor measures the shortest distance, this code moves the servo to that location
    if(lowestVal == distance1){
    myServo.write(servoPos);
    if(lowestVal == distance2){
      myServo.write(servoPos+36);
    if(lowestVal == distance3){
      myServo.write(servoPos+72);
    if(lowestVal == distance4){
      myServo.write(servoPos+108);
    if(lowestVal == distance5){
      myServo.write(servoPos+144);
    //Gives enough delay for servo to move to the right location
The problem I'm having is that, no matter which distance is lowest, the servo doesn't move. When testing, I was able to make other things happen if one of the distances was lowest, such as turning on an LED. Does anyone know why the servo movement specifically wouldn't work? Thanks in advance!
Please post the full sketch rather than a snippet
Have you tried printing the values that you are testing and what sets those values ?
Write a program that JUST makes the servo move!
Here's my code. As you can see, I do print the values. I tried printing out the lowestVal and that worked fine, I just can't get the servo to move.
//This stuff just copies in servo library and sets a bunch of variables so I know which pins go to what
#include <Servo.h>
const byte trigPin1 = 2;
const byte echoPin1 = 3;
const byte trigPin2 = 4;
const byte echoPin2 = 5;
const byte trigPin3 = 6;
const byte echoPin3 = 7;
const byte trigPin4 = 8;
const byte echoPin4 = 9;
const byte trigPin5 = 10;
const byte echoPin5 = 11;
const byte servoPin = 12;
float duration;
unsigned int distance;
unsigned int servoPos = 0;
Servo myServo;
  //Sets the trig pins to outputs and echopins to inputs, so the sensors can work
  pinMode(trigPin1, OUTPUT);
  pinMode(echoPin1, INPUT);
  pinMode(trigPin2, OUTPUT);
  pinMode(echoPin2, INPUT);
  pinMode(trigPin3, OUTPUT);
  pinMode(echoPin3, INPUT);
  pinMode(trigPin4, OUTPUT);
  pinMode(echoPin4, INPUT);
  pinMode(trigPin5, OUTPUT);
  pinMode(echoPin5, INPUT);
  myServo.attach(servoPin);
  //This is all stuff I just copied from an hc-sr04 guide, don't mess with it
  digitalWrite(13, LOW);
  digitalWrite(trigPin1, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin1, HIGH);
  delayMicroseconds(10);
  int duration1 = pulseIn(echoPin1, HIGH);
  digitalWrite(trigPin2, LOW);
  digitalWrite(trigPin2, HIGH);
  int duration2 = pulseIn(echoPin2, HIGH);
  digitalWrite(trigPin3, LOW);
  digitalWrite(trigPin3, HIGH);
  int duration3 = pulseIn(echoPin3, HIGH);
  digitalWrite(trigPin4, LOW);
  digitalWrite(trigPin4, HIGH);
  int duration4 = pulseIn(echoPin4, HIGH);
  digitalWrite(trigPin5, LOW);
  digitalWrite(trigPin5, HIGH);
  int duration5 = pulseIn(echoPin5, HIGH);
  //More math from the guide
  int distance1 = (duration1 * .0343) / 2;
  int distance2 = (duration2 * .0343) / 2;
  int distance3 = (duration3 * .0343) / 2;
  int distance4 = (duration4 * .0343) / 2;
  int distance5 = (duration5 * .0343) / 2;
  if (distance5 < 200 || distance > 1000) {
    distance5 = 1000;
  } if (distance4 < 200 || distance4 > 1000) {
    distance4 = 1000;
  } if (distance3 < 100 || distance3 > 1000) {
    distance3 = 1000;
  } if (distance2 < 100 || distance2 > 1000) {
    distance2 = 1000;
  } if (distance1 < 100 || distance1 > 1000) {
    distance1 = 1000;
    //This entire code thing only works if the lowest value is significant, not just if it's like 1000
  //Prints out values of each distance measurement
  Serial.println("Distances: ");
  Serial.println(distance1);
  Serial.println(distance2);
  Serial.println(distance3);
  Serial.println(distance4);
  Serial.println(distance5);
  Serial.println(lowestVal);
  //If the servo has rotated to its maximum in the cycle, it switches back to 0. Otherwise, it adds 4 degrees
  if(servoPos == 32){
  servoPos = 0;
  delay(400);
  else{
  servoPos = servoPos + 4;
    delay(10);
I know how to work servos and it doesn't seem to me like I'm doing anything wrong. At another point in my program (which I posted below in a reply) I control the servo, and it moves fine then. It just doesn't work inside the if() function
That might be the Tx, or Rx pin on the controller. Very unwise to use that pin.
That's nonsense. "if" has no technical effect what so ever on I/O activity. The reason is that the condition in the if-statement is not met.
Use serial monitor and serial print of the decisive variables, before that "if".
It would be, yes, if it was used that way.
a7
Still members feel offended when being asked for code, schematics....
Some of us know not to rule out any kind of mistake. There's no limit for "inventions" made by some members picking up things in the gutter.
