Hey guys, I need some help. My servomotor moves when I am adjusting the potentiometer. But it doesn't move(left, right middle) when I use the toggle switch. What's wrong in my code?
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 0; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
//Toggle Switch
int toggleA = 5;
int toggleB = 10;
//Toggle Switch Status
int toggleAstatus;
int toggleBstatus;
//Center position (1500usec)
const int center = 1500;
//angle added for 600us
int x = 60;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
//Serial Monitor
Serial.println("=====Servo Test======");
//Toggle Switch pinMode
pinMode(toggleA, INPUT_PULLUP);
pinMode(toggleB, INPUT_PULLUP);
//Servo to center position
myservo.writeMicroseconds(center);
Serial.println("Servo to center position");
toggleswitch();
void toggleswitch()
//Toggle Switch Status Reads HIGH/LOW
toggleAstatus = digitalRead(toggleA);
toggleBstatus = digitalRead(toggleB);
//Toggle Switch Positioning Control of Servo
//(LEFT, CENTER, RIGHT)
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
if (val >= 20 && val <= 80, toggleAstatus == HIGH && toggleBstatus == HIGH)
Serial.println("Servo Adjusted to:");
Serial.println(val);
myservo.write(val);
if (val >= 20 && val <= 80, toggleAstatus == LOW)
Serial.println("Servo adjusted to:");
Serial.println(val + x);
myservo.write(val + x);
if (val >= 20 && val <= 80, toggleBstatus == LOW)
Serial.println(val - x);
myservo.write(val - x);
My code uploads fine, it works with my potentio when I'm adjusting the position but my servo doesn't move everytime I used the toggle switch and the serial monitor prints that the servo moves to certain position.
Yes, I'm using another DC supply 6V(rating of servo), just like I what told earlier, the servo moves when I'm adjusting it with my potentiometer. Then when I tried to use the toggle switch, it doesn't move.
myservo.write(val);
What is the interval between those two servo writes?
You've obviously made some changes so please post the current version of the complete code.
So the pot moves the servo to a position set by val, maybe 30. When you set the switch so toggleAstatus is LOW serial monitor correctly says servo is at 90 but the servo doesn't move from 30. Is that what you are seeing?
One immediate problem with your logic, if toggleBstatus is LOW you subtract 60 from val. 30-60 = -30 and that is an invalid value because servo.write() only takes 0 to 180 not negative values. What are you actually trying to make happen?
Noobie Here, I've been trying to do this thing since last week. But still I cannot get the right code for this.
This is how I want this to work. I want to control the angle of my servo using the potentiometer. After that, I want to use the toggle switch to rotate the servo(left,right and middle).
What happened was I gave my desired angle by the use of potentio, but everytime I move the toggle switch, my servo doesn't respond.
I post this 2 times already, and this is my third time. Badly needed help.
This is my code
Testing and Measuring the Servo
Setting the Pulse Width of Servo using Potentiometer
Controlling the Rotation of Servo (CW/CCW)
Measure the current of Servo
Measuring the angle of Servo with given PW (600usec & 400usec)
Test the speed of Servo (14ms & 20ms)
Values presented in a TFT
#include <Servo.h>
//Toggle Switch
int toggleA = 5;
int toggleB = 10;
int toggleAstatus;
int toggleBstatus;
int x = 600;
//Serial Monitor
toggleswitch();
void toggleswitch()
val = map(analogRead(potpin), 0, 1023, 280, 2720); // scale it to use it with the servo (value between 280(60°), 2720(120°))
Serial.println("Position");
if (val > 1200 && val < 1800)
if (toggleAstatus == HIGH && toggleBstatus == HIGH)
myservo.writeMicroseconds(val);
if (toggleAstatus == LOW)
myservo.writeMicroseconds(val + x);
if (toggleBstatus == LOW)
Serial.println(abs(val - x));
myservo.writeMicroseconds(abs(val - x));
else if (val < 1199)
Serial.println("Servo can't adjust to that value");
else if (val > 1801)
This is my code now, but still my servo doesn't respond to the toggle switch. I'm having a feeling that it is because the potentiometer holds the position of my servo but I'm not sure about it. And still don't know what to do.
#include <Servo.h>
//Toggle Switch
int toggleA = 5;
int toggleB = 10;
int toggleAstatus;
int toggleBstatus;
int x = 600;
//Serial Monitor
toggleswitch();
void toggleswitch()
