Hi, I have a simple setup here I think but have 2 problems.
- at rest the servo pulses, consistently every second or so
- as soon as the button is pushed I want the led to light, but it first lights when the servo is moving, then goes out then flashes a couple times as the servo gets to its final position, and then goes steady on.
final setup is for zone control on a base board heat system, I will have six servos controlling the valves on the zones, input will be from thermostats. Pin 14 tells the circulating pump to turn on through a relay.
I am using an uno and tower pro mg995 servos from ebay
Any advice would be great,
Thanks, tom
#include <Servo.h>
Servo servo_pin_5;
Servo servo_pin_6;
Servo servo_pin_11;
Servo servo_pin_10;
Servo servo_pin_9;
Servo servo_pin_3;
pinMode( 14 , OUTPUT);
servo_pin_6.attach(6);
pinMode( 2 , INPUT);
servo_pin_9.attach(9);
servo_pin_3.attach(3);
servo_pin_11.attach(11);
pinMode( 8 , INPUT);
pinMode( 12 , INPUT);
servo_pin_10.attach(10);
pinMode( 13 , INPUT);
servo_pin_5.attach(5);
pinMode( 7 , INPUT);
pinMode( 4 , INPUT);
if (digitalRead( 2))
servo_pin_3.write( 90 );
servo_pin_3.write( 0 );
if (digitalRead( 4))
servo_pin_5.write( 90 );
servo_pin_5.write( 0 );
if (digitalRead( 7))
servo_pin_6.write( 90 );
servo_pin_6.write( 0 );
if (digitalRead( 8))
servo_pin_9.write( 90 );
servo_pin_9.write( 0 );
if (digitalRead( 12))
servo_pin_10.write( 90 );
servo_pin_10.write( 0 );
if (digitalRead( 13))
servo_pin_11.write( 90 );
servo_pin_11.write( 0 );
if (( digitalRead( 2) || ( digitalRead( 4) || ( digitalRead( 7) || ( digitalRead( 8 ) || ( digitalRead( 12) || digitalRead( 13) ) ) ) ) ))
digitalWrite( 14 , HIGH );
digitalWrite( 14 , LOW );
