i include a customized version pcRead(), included in the following, in almost all my projects to support testing of various aspects of the code as it developes and to support diagnostics. I'll add commands for functions specific to the application i'm working on
shouldn't the "tool" your searching for be part of your code?
// pcRead - debugging using serial monitor
const char version [] = "PcRead 240209a";
int debug = 0;
// process single character commands from the PC
#define MAX_CHAR 10
char s [MAX_CHAR] = {};
int analogPin = 0;
void
pcRead (void)
static int val = 0;
if (Serial.available()) {
int c = Serial.read ();
switch (c) {
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
val = c - '0' + (10 * val);
break;
case 'A':
analogPin = val;
Serial.print ("analogPin = ");
Serial.println (val);
val = 0;
break;
case 'D':
debug ^= 1;
break;
case 'I':
pinMode (val, INPUT);
Serial.print ("pinMode ");
Serial.print (val);
Serial.println (" INPUT");
val = 0;
break;
case 'O':
pinMode (val, OUTPUT);
Serial.print (val);
Serial.println (" OUTPUT");
val = 0;
break;
case 'P':
pinMode (val, INPUT_PULLUP);
Serial.print (val);
Serial.println (" INPUT_PULLUP");
val = 0;
break;
case 'a':
Serial.print ("analogRead: ");
Serial.println (analogRead (val));
val = 0;
break;
case 'c':
digitalWrite (val, LOW);
Serial.print ("digitalWrite: LOW ");
val = 0;
break;
case 'p':
#if !defined(ARDUINO_ARCH_ESP32)
analogWrite (analogPin, val);
Serial.print ("analogWrite: pin ");
Serial.print (analogPin);
Serial.print (", ");
val = 0;
#endif
break;
case 'r':
Serial.print ("digitalRead: pin ");
Serial.print (val);
Serial.println (digitalRead (val));
val = 0;
break;
case 's':
digitalWrite (val, HIGH);
Serial.print ("digitalWrite: HIGH ");
val = 0;
break;
case 't':
Serial.print ("pinToggle ");
digitalWrite (val, ! digitalRead (val));
val = 0;
break;
case 'v':
Serial.print ("\nversion: ");
Serial.println (version);
break;
case '\n': // ignore
break;
case '?':
Serial.println ("\npcRead:\n");
Serial.println (" [0-9] append to #");
Serial.println (" # A - set analog pin #");
Serial.println (" # D - set debug to #");
Serial.println (" # I - set pin # to INPUT");
Serial.println (" # O - set pin # to OUTPUT");
Serial.println (" # P - set pin # to INPUT_PULLUP");
Serial.println (" # a - analogRead (pin #)");
Serial.println (" # c - digitalWrite (pin #, LOW)");
Serial.println (" # p - analogWrite (analogPin, #)");
Serial.println (" # r - digitalRead (pin #)");
Serial.println (" # s - digitalWrite (pin #, HIGH)");
Serial.println (" t - toggle pin output");
Serial.println (" v - print version");
Serial.println (" ? - list of commands");
break;
default:
Serial.print ("unknown char ");
Serial.println (c,HEX);
break;
void
loop (void)
pcRead ();
void
setup (void)
#if defined(ARDUINO_ARCH_ESP32)
Serial.println ("esp32");
#endif
