Servos for -70°C
Just a brainstorming idea: Could the gas release be handled by some kind of pressure relief valve that works completely automatically and provides sufficient cross-section even at a small pressure difference? This would probably also be extremely lightweight.
Just have a look at check valves for air ducts.
Regarding the ballast: gravity still helps, and a solenoid valve should work. Concerning the ethanol, it shouldn’t freeze either.
Reminds me of a work colleague, back in the seventies, who fixed mains-powered shavers.
He got so sick of cleaning out all the beard hairs before a repair that one day he dangled the running shaver, held by the powercord, in ethanol.
That seemed to work well until he removed it. To his surprise it burst into flames :rofl:
The shape-memory alloys can exert a surprising amount of force (up to almost 8lb.)
Although they also consume an annoying amount of current. (4A for the 0.5mm 8lb wire), since they work by self-heating from that current.)
We are using an ESP32-s3, but we also tryed an Arduino and both worked pretty
well...
Maybe this could work, but we would like to be able to control the gas release and not just let it run automatically.
Maybe it would be really an option to use a solenoid valve, but that will not help for the venting system, so the problem is still the same for that...
Our total current is very limited (in peak 3A) and self-heating at -70°C seems to be even harder. Therefore we sadly can't use them.
Possible solution:
Servos are designed to typically move a relatively short lever quite quickly to a specific angular position. To achieve this, they usually require a comparatively powerful electric motor and a gearbox plus casing—all of which are not exactly lightweight, especially if the gearbox uses metal gears.
In this case, servos optimized for speed are unnecessary and also consume some power even when idle. For that reason, many years ago in a completely different application, I attached a tiny electric motor directly to a threaded rod (via a centered bore and bonding the motor shaft using the strongest Loctite). This allowed me to move a nut (mounted at the end of a plastic tube) over a long distance.
Such a very simple and lightweight linear actuator could also serve your purpose well, provided that speed is not a critical factor.
Would it be possible to mount the electronics, battery, and servos all within a central, somewhat insulated housing, and drive the ballast drop and gas vent valves remotely through a cable?
Do you have any idea of the temperature extremes? Your main concern seems to be the -70 degrees, but in direct sunlight at high altitude the daytime temperature might be significant. You might want to do a multi-day test with temperature cycling to see if the electronics can reliably survive.
What were the results of the test where you did multiple inflation/deflation of the balloon a -70ºC?
It won't be possible to have that much insulation to prevent everything from cooling down, especially during a flight over multiple days. That would be much too heavy, we have already calculated that.
Frequently seen in CD/DVD player mechanisms and floppy drives.
Simple to construct. Question still remains if the sleeve bearings of the motor are the problem. I have seen mentioning an overnight acetone bath in other posts.
Leo..
I had a concern at first – that the bearing might “shrink onto the shaft” at very low temperatures like −70 °C.
If you look at the numbers though, it’s not that dramatic. A small motor like that (around 10 mm diameter, ~1.2 mm shaft) typically has something like 5–20 µm clearance in the sleeve bearing.
Now, cooling from room temp down to −70 °C gives roughly a 90 K drop. The bronze bearing shrinks a bit more than the steel shaft, so yes, the clearance gets smaller. But we’re talking on the order of maybe ~0.5–1 µm difference.
So in the end:
  • clearance gets slightly tighter
  • but it doesn’t disappear
In other words, it’s very unlikely that the bearing actually locks up just from thermal contraction.
@Wawa, you are right: What does become a real problem is the lubricant. The oil in those sintered bearings gets extremely viscous (or basically solid), so you lose proper lubrication. That means:
  • much higher friction
  • poor or no startup
  • general “stuck” feeling, even though nothing is mechanically jammed
Bottom line:
The geometry change is real but small. The lubricant behavior at −70 °C is what usually kills it, not the bearing shrinking onto the shaft.
So Back to what was already discussed 30 post ago
OK, but what if the temperature-induced bearing shrinkage had actually led to the shaft seizing? Then the whole lubrication discussion would have been irrelevant.
@tigger mentioned it, but I actually ran the numbers on that — which nobody had done before ...
Yes that was a good point
Thanks to you all for helping! We actually found a solution working together with volz servos. They sell servos that also work at -70°C. The prices for those are pretty high, but we managed to get some
Yeahh, big thanks to Volz-Servos, they sponsored us 2x DA 14-N.LT (Low-Temperature) Servos! They should work fine up to –70 °C!
Care to reveal how high?
I would guess that a realistic expectation is on the order of a few thousand euros per servo, sometimes significantly more depending on certification and customization.
Definitely not the solution for the average hobbyist.
