Hello,
I am just trying to read my holding registers in arduino due, which is set as a slave, and read the registers using the labview example below but I am getting values which do not align with whats in the holding register, "holdingRegs"? I am not sure what I am doing wrong. I have attached my files below including the labview file I am using to test. I would like to get it too where I can read a variable stored in my holding register from my arduino due to the register in the VI to verify Modbus over ethernet is working
I have my holding register set equal to 1 to verify but I am getting zero in labview and unknown values in my serial monitor when the Labview file is running
I found the slave library for the arduino DUE from here https://drive.google.com/drive/folders/0B0B286tJkafVYnBhNGo4N3poQ2c
I am using an ethernet shield 2 on my DUE
SimpleModbusSlave_DUE.cpp (9.24 KB)
SimpleModbusSlave_DUE.h (2.56 KB)
MB Ethernet Example Master - Copy.zip (17.2 KB)
ArduinoDueLabviewEthernet_2.ino (5.15 KB)
