Hi All, I have a couple of variables I would like to change using the serial monitor. Below is code that I found from this tutorial: Serial Input Basics - updated
Currently, if I type a value in the serial monitor, the MoveCount will change. However, I would like to be able to type "MoveCount = 20" in the serial monitor to change specific variables.
There may be a tutorial out there for this, but I can't seem to find anything to help me. If someone can help with this or provide a link, it would be greatly appreciated.
int MoveCount=10;
const byte numChars = 32;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
if (Serial.available() > 0) {
rc = Serial.read();
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewNumber() {
if (newData == true) {
MoveCount = 0; // new for this version
MoveCount = atoi(receivedChars); // new for this version
Serial.print("Move Count set to"); // new for this version
Serial.println(MoveCount); // new for this version
newData = false;
here's a .ino that include pcRead() which i have in almost all my programs to help debug and test
it uses single character commands, optionally preceded by a numeric value. it gets customized for every application. multiple commands can be entered on the same line
// pcRead - debugging using serial monitor
const char version [] = "PcRead 201114a";
int debug = 0;
// toggle output bit
int
readString (
char *s,
int maxChar )
int n = 0;
Serial.print ("> ");
do {
if (Serial.available()) {
int c = Serial.read ();
if ('\n' == c)
s [n++] = c;
if (maxChar == n)
} while (true);
return n;
// process single character commands from the PC
#define MAX_CHAR 10
char s [MAX_CHAR] = {};
int analogPin = 0;
void
pcRead (void)
static int val = 0;
switch (c) {
case '0':
case '1':
case '2':
case '3':
case '4':
case '5':
case '6':
case '7':
case '8':
case '9':
val = c - '0' + (10 * val);
case 'A':
analogPin = val;
Serial.print ("analogPin = ");
Serial.println (val);
val = 0;
case 'D':
debug ^= 1;
case 'I':
pinMode (val, INPUT);
Serial.print ("pinMode ");
Serial.print (val);
Serial.println (" INPUT");
val = 0;
case 'O':
pinMode (val, OUTPUT);
Serial.print (val);
Serial.println (" OUTPUT");
val = 0;
case 'P':
pinMode (val, INPUT_PULLUP);
Serial.print (val);
Serial.println (" INPUT_PULLUP");
val = 0;
case 'a':
Serial.print ("analogRead: ");
Serial.println (analogRead (val));
val = 0;
case 'c':
digitalWrite (val, LOW);
Serial.print ("digitalWrite: LOW ");
val = 0;
case 'p':
#if !defined(ARDUINO_ARCH_ESP32)
analogWrite (analogPin, val);
Serial.print ("analogWrite: pin ");
Serial.print (analogPin);
Serial.print (", ");
val = 0;
#endif
case 'r':
Serial.print ("digitalRead: pin ");
Serial.print (val);
Serial.println (digitalRead (val));
val = 0;
case 's':
digitalWrite (val, HIGH);
Serial.print ("digitalWrite: HIGH ");
val = 0;
case 't':
Serial.print ("pinToggle ");
digitalWrite (val, ! digitalRead (val));
val = 0;
case 'v':
Serial.print ("\nversion: ");
Serial.println (version);
case '\n': // ignore
case '"':
while ('\n' != Serial.read ()) // discard linefeed
readString (s, MAX_CHAR-1);
Serial.println (s);
case '?':
Serial.println ("\npcRead:\n");
Serial.println (" [0-9] append to #");
Serial.println (" A # - set analog pin #");
Serial.println (" D # - set debug to #");
Serial.println (" I # - set pin # to INPUT");
Serial.println (" O # - set pin # to OUTPUT");
Serial.println (" P # - set pin # to INPUT_PULLUP");
Serial.println (" a # - analogRead (pin #)");
Serial.println (" c # - digitalWrite (pin #, LOW)");
Serial.println (" p # -- analogWrite (analogPin, #)");
Serial.println (" r # - digitalRead (pin #)");
Serial.println (" s - digitalWrite (pin #, HIGH)");
Serial.println (" t -- toggle pin # output");
Serial.println (" v - print version");
Serial.println (" \" - read string");
Serial.println (" ? - list of commands");
default:
Serial.print ("unknown char ");
Serial.println (c,HEX);
void
loop (void)
pcRead ();
void
setup (void)
#if defined(ARDUINO_ARCH_ESP32)
Serial.println ("esp32");
#endif
