Set/Reset/ LatchBits
I have 32-bit MCU. The port uses 32 digital IO functionality.
I am looking for a sample code to Latch a particular bit/particular pin in PORTA Set/RESET function particular bit In port A.
Can someone guide me on how it can be done using AND/OR/XOR operation?
digitalRead() will capture the state of the pin when read
I assume you have some reason for not using the digitalRead() and digitalWrite() functions.
To set a bit first read the register (using the proper built-in) then OR the bit you want set with the value you read and then write the register back. To clear a bit AND in the complement of the bit you want to clear.
See
  Arduino direct port manipulation
with your favorite search engine.
byte thePort = PORTA;
then
 PORTA = bitSet(thePort, 3);
or
PORTA = bitClear(thePort, 3);
will turn on or off bit 3 of the port.
Which must be an output pin to be seen, obvsly I hope.
You could go out and learn how to do it as @oldcurmudgeon says, it is worth knowing that kind of bit operating don't rely on some fancy functions that do the same thing.
a7
Which 32 bit CPU?
